Floating Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-01-2007, 11:09 PM   #1
Floating Walls
hello! i'm new to this site, so i don't know if this topic was mentioned already. I'm wondering how to attach a floating wall from the floor to a floating wall to the joists? For example, my exterior walls are floating on the floor and i want to float my interior walls to the joists, just because i think it's better for installing the doors.
Thx
KenG
KenG is offline   Reply With Quote
Old 12-02-2007, 09:57 AM   #2
Rewards Points: 5,336
What is a floating wall?
Ron
Old 12-02-2007, 11:02 AM   #3
It'ds where you have your standard wall frame but it's about 1.5inch short of the joist, then you drive a spike through your top plate into your joist, so if the floor heeves then the wall will move with the floor.
Old 12-02-2007, 11:34 AM   #4
Darylh's Avatar
This is how we used to build floating walls in log homes
Darylh is offline   Reply With Quote
Old 12-02-2007, 11:54 AM   #5
Daryl thx for the pic! My exterior walls are floating from the floor, but i want my interoir walls to float at the joists, do you know how to attach the two walls together? Because i don't want the drywall cracking in the corners if i don't attach the two.
Thx
KenG
Old 12-02-2007, 12:13 PM   #6
Darylh's Avatar
Any reason why you can not make your interior walls the same as your exterior walls. I don't think it's possible to tie these two different set ups togeather and stop any drywall cracking.
Old 12-02-2007, 12:22 PM   #7
I'm thinking of when i put the doors in, how will they float from the floor?
Old 12-02-2007, 01:08 PM   #8
Darylh's Avatar
Your doors are not fastened to the floor. You know some pics would be nice here or a better understanding of what going on because I am afraid to say to much here and give the wrong advise.
Old 12-02-2007, 01:29 PM   #9
I'm petty sure i got it figured out on how to float my doors from the floor.
Thx
KenG
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
help! my walls are troubled donnamarie General DIY Discussions 5 08-29-2007 01:08 PM
