| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Basement Remodeling: Setting an Agenda
by Expert Village
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Remodeling a basement can be a big task. When you want to remodel your basement, you first want to think about how big it is and what you want to do, with... Read More »
Basement Remodeling: Bearing Walls Framing
by Expert Village
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Structure Side Supports for Basement Walls
by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. On the sides of each side I want dirt to fill in there and I would be building up a wall in between the cinder block wall the dirt wall to keep the dirt and sand that I have back... Read More »
Basement Remodeling: Plumb & Level Framing
by Expert Village
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
Basement Remodeling: Project Schedules
by Expert Village
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
