Flipper Top Cabinet Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 01:12 PM   #1
Flipper top cabinet doors
I am remodeling my camper, I was wanting to make the lower cabinet doors to flip up and slide in for easier access. Any idea of how to do this without a lot of cost? I have seen that they have hinges that do this, but isn't there an easier way?
Novicecarpenter is offline   Reply With Quote
Old 08-06-2009, 01:20 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
Go to a Rokkler (sp?) store and explain what you want to do. They can get almost any type of hardware/hinges/mechanisms, especially dome specialty items. With the right hardware, the doors will be easy.
concretemasonry is offline   Reply With Quote
Old 08-06-2009, 01:52 PM   #3
47_47's Avatar
Rewards Points: 44
Yup Rockler will probably have the mechanisms you need, but they won't be cheap and will take up space. How about 1/4" sliding bypass doors? Or maybe even tambour doors?
47_47 is offline   Reply With Quote
Old 08-07-2009, 09:38 AM   #4
flipper doors
Thank you for all you help. I did go to Rockler and yes they were pricey.
Just thought there would be a simpler way. Tambour doors! No way remember I am a novice. I looked at that also, didn't think that I could tackle that.
Old 08-07-2009, 10:40 AM   #5
47_47's Avatar
Rewards Points: 44
Tambour doors are just thin, uniform slats glued to a flexible fabric backing, which run in a groove. They are doable with a table saw and a router.
Another possibility, instead of sliding doors, make a deep saw kerf in the top of the door opening and a shallow one in the bottom. The width of the kerf will be the door thickness. This way you can slide a panel up and in and remove it when necessary.
Replacing just the kitchen cabinet doors? imola ghost Remodeling 7 02-24-2010 12:03 PM
building my own kitchen cabinet doors... Jeremy Hillary Boob, PhD Carpentry 6 05-06-2009 12:38 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
Kitchen cabinet doors LOUSY CARPENTER Carpentry 3 02-01-2009 08:07 PM
Cabinet doors made of hardwood and fiberboard sil Remodeling 17 11-19-2007 11:18 AM
