"Flexible" Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 01:35 PM   #1
Git
Hello
I would like to install some crown molding in my house, but I have a couple of areas that are going to cause me problems.
The front door of the house is in a 'turret' - which is basically two stories tall and is 12' in diameter. So not only would I look to install crown molding in the turret, there are some adjoining rooms where part of the walls are curved
What products are available - foam, what? Any other tips or tricks?
appreciate your help
Git is offline   Reply With Quote
Old 09-14-2010, 01:45 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Trim supply companies have the flexible moldings of most kinds but are a little pricey, also look online.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-14-2010, 09:20 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
Zago mouldings
Millertyme is offline   Reply With Quote
Old 09-16-2010, 12:37 PM   #4
Supply houses are a good place to look. They should have a selection of flexible moldings. But as jiju1943 says, they will be pricey. And they might not have your profile. Another alternative is to use drywall compound and create your own in place. Take a plastic putty knige slightly larger than the profile of your existing, desired molding and cut the profile into the knife. Taking a small piece of the molding and tracing the profile onto the plastic is a good start. Cut and sand to proper size. No the hard part. Start adding drywall mud ceiling/wall joint to fill the space. Use a fast setting mud - 5 minutes. Use a knife that is shorter than the one that you made the template out of. If you used a five inch knife for your profile, use a four inch for filling. Once the joint is filled, add additional coats using your profiled knife. Rinse and repeat. Sand as necessary.
unlvrebel is offline   Reply With Quote
Old 09-16-2010, 12:50 PM   #5
Git
Well, thanks for the suggestions - I located a local supplier who sells a resin based preformed molding that will match the radius, I will have to go in and see how much $$$$
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
making own crown molding marin001 Carpentry 7 03-29-2010 12:08 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
