Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-13-2009, 04:35 PM   #1
Default flat roof fencing
We took off fencing off a flat roof due to the replacement of the roof
with roll down material
now the fencing needs to be replaced
question is How do we replace fencing without nailing into the new roof ?
marshycoco is offline   Reply With Quote
Old 10-13-2009, 07:28 PM   #2
Default What was detailed in the Prints and Specs?
Let me guess, there weren't any prints or specs for this job. Right?
The correct way would have been to anchor the pipes rails supporting the fencing before the insulation and membrane was installed, then flash around them.
A second method is to now anchor the pipe bases directly to the roof, screwing through the new membrane into the solid roof deck, then install conical plumbing boot penetration flashings around the pipes and covering the anchoring flanges.
http://www.flashcomfg.com/downloads/singleply-all.pdf
If the roof deck is insulated you have additional problems, as the post bases must be thru bolted with some type of solid blocking under the base to replace the insulation since it has no strength.
The best solution is to hire a roofing designer to visit the site and give specific recommendations for this situation, rather than blind internet suggestions such as mine.
MI-Roger is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking the flashing and resealing all seams. You want to make sure that you check all of the flashing around all of the vents, the fireplace and any other protruding objects or... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
You can beautify the grounds of your home by building a pond and reveling in the serenity it provides. Just follow these steps. Read More »
How to Frame Roof Valleys
How to Frame Roof Valleys by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. It is important to maintain even tile courses each side of a gable and a roof wherever possible when using burrow trims. Uneven length trims cut at... Read More »
How to Find Total Duct Loss
How to Find Total Duct Loss by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Now we are looking for the total loss even the loss to the inside, even the loss where our tape might be leaking or... Read More »
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 06:08 PM
Flat roof headache The Barber Roofing 7 05-17-2008 07:48 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 08:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
