Flat Roof - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-21-2011, 03:56 PM   #1
flat roof
hi all i am building a porch with a flat roof, i have cut my timbers into the excisting brickwork and run it onto the new wall, i am then goint to lift the first 2 rows of tiles to the excisting roof and run my new felt under the first 2 rows of tiles then onto my new roof. is this ok to do this.
Many Thanks
chrissy1996 is offline   Reply With Quote
Old 11-21-2011, 04:12 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
a flat roof needs to be properly flashed with metal where it meets the house.. and tar paper is no good for the roof, it needs to be rolled roofing or torched on
woodworkbykirk is offline   Reply With Quote
Old 11-22-2011, 08:08 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
It sounds like you intend to tie in a flat roof at the base of a sloped roof. Unless you pay particular attention to details, you will have a leak waiting to happen. What is the final waterproof material you will use for the flat roof? What is the sloped roof made from? How much slope? You said "tiles". By that do you mean true roofing tiles or shingles? What is your location? Snow load?
Old 11-22-2011, 10:42 AM   #4
Chicago, IL
Michael Thomas's Avatar
Originally Posted by chrissy1996 View Post
hi all i am building a porch with a flat roof, i have cut my timbers into the excising brickwork and run it onto the new wall, i am then goint to lift the first 2 rows of tiles to the excising roof...
Tiles, or shingles?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 04:28 PM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
Flat roof related questions christy123 Roofing/Siding 8 12-09-2008 11:30 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
