Fixing A Swollen Steel Entry Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 03:38 PM   #1
Fixing a swollen steel entry door
My parents have a leaded glass entry door that over-expanded (the foam insulation inside the door over-expanded after installed and bellied out the door skin) sitting in their basement. I am going to confirm if the hinges and knob line up. If they do, I would love to replace our solid slab front door with this one. Any one have any ideas if and how this can be fixed so it can be used?
JRCL is offline   Reply With Quote
Old 03-31-2013, 04:06 PM   #2
funfool's Avatar
Rewards Points: 534
Please tell more, I have installed many doors over many years, what you say makes no sense to me.
Are you saying the door is now thicker then it should be?
What exactly expanded?
funfool is offline   Reply With Quote
Old 03-31-2013, 04:12 PM   #3
The expanding foam used for insulating the door (the core of the door) over-expanded and bellied out the door skin. So, it looks like someone pressed the skin outwards from the interior of the door. I understand this is common with dark painted doors that have a storm door added and get a large amount of direct sunlight in the summer.
Old 03-31-2013, 04:19 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
it sounds like it was sitting near the furnace or some other source of heat.. based on the issue the door is toast. toss it
woodworkbykirk is offline   Reply With Quote
Old 03-31-2013, 04:21 PM   #5
Roofmaster
Rewards Points: 2,210
Bad Foam. Maybe you can get a new door out of it, but maybe dad already did? Isocyanurate foam is used on commercial low slope roofs and it is subject to a lot more heat up there than in a door, so the problem is probably poorly formulated foam.
Old 03-31-2013, 04:36 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
How old is the door? Sounds like it should be covered under warranty if it is less than 10 years old.
Old 03-31-2013, 04:57 PM   #7
The problem occurred while the door was hanging. Door has already been replaced under warranty and is currently just taking up space in the basement. Just looking to see if it can be fixed and reused.
Old 03-31-2013, 05:19 PM   #8
funfool's Avatar
Rewards Points: 534
Might look great on my garden shed.
I would not bother with it on my front door to the house.
Old 03-31-2013, 06:26 PM   #9
kwikfishron's Avatar
Rewards Points: 998
If you like the glass there's no reason it (the glass) can't be salvaged and used for whatever you want. As far as the door itself, as others said...it's trash.
kwikfishron is online now   Reply With Quote
Weatherstripping entry door to garage steppinthrax Windows and Doors 2 12-12-2011 11:28 AM
laminate transition at entry door moneymgmt Carpentry 4 03-16-2010 09:59 AM
Entry Door installation... Advice needed! mburgess44 General DIY Discussions 19 09-12-2009 07:46 PM
Steel Entry Door Issues framinghammer Carpentry 6 06-25-2009 05:50 AM
steel door sticking in frame bruce_hyman Building & Construction 10 12-20-2008 07:17 AM
