Fixing A Removable Glazing Panel - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 10:27 AM   #1
Har
Fixing a Removable Glazing Panel
I have an Andersen W4 casement window with broken glass in the interior removable glazing panel. Andersen is no longer selling the glazing panels from pre-1989 windows. I can break up the glass to remove it, but how does the glazing panel frame come apart in order to insert a new pane? Are the corners press-fit together, so that I should just tap them apart? Thanks.
Har is offline   Reply With Quote
Old 08-23-2011, 11:43 AM   #2
Rewards Points: 5,336
Many local glaziers will be able to make a replacement insulated panel for the window.
Well, they can around here.
Ron
B. Franklin 1759
Old 08-23-2011, 05:33 PM   #3
Har
If possible, I would like to keep the frame of the glazing panel--it is one of three adjacent windows and they all match. I don't see any screws holding the frame together, and the glass is a little loose in the frame, so if I can figure out how to open the sections of the frame then I (or a glazier) could replace the glass and close up the frame. There are seams between the frame pieces in the corners, that's why I thought the sides were pressed-fit together and could be knocked apart.
Old 08-23-2011, 06:48 PM   #4
The glass is removeable from the wood frame. There are 3 critical dimensions to make sure the new panel fits. Length and width of the glass and the thickness of the spacer between the glass.
Ron
B. Franklin 1759
Old 08-23-2011, 08:06 PM   #5
Har
Thanks. I have the glazing panel out of the window. It's a thin metal frame that holds the (broken) glass. I want to take apart the frame to replace the glass. The frame isn't riveted and doesn't seem to be glued but maybe press-fit together? The sides, top and bottom appear to be four pieces. The glass is slightly loose in the frame.
Old 11-16-2012, 10:46 AM   #6
It's been over a year since you posted, but the metal frames come apart. There are four screws located at the corners. Simply pry back the aluminum fin to expose the screws and disassemble the frame. When you replace the glass be sure to reglaze or caulk to prevent condensation between the panes. And while you're at it, check to make sure the weep holes are cleaned out or again, you'll get condensation between the panes.
pshomestead is offline   Reply With Quote
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Fixing a door with broken out panel justdon Carpentry 2 09-09-2007 08:35 AM
