-   -   fixing a hole in a masonite door (http://www.diychatroom.com/f14/fixing-hole-masonite-door-86596/)
dannyrh80 11-13-2010 01:52 PM
its about a 4-inch hole
Bud Cline 11-13-2010 02:58 PM
:whistling2::whistling2::whistling2:
Ron6519 11-14-2010 09:17 PM
Square up the hole. Glue two wood strips to the inside of the door. When it dries, patch the hole with the same thickness material. Fill any voids with a wood filler. Sand, prime and paint.
Ron
troubleseeker 11-17-2010 10:24 PM
For the cost of a "masonite" door slab, if you have the ability to install the hinges and lockset, I'd trash it. If it is a "wood grain" finsh, it will absolutely look like crap when repaired, and if a smooth finish, by the time you try to fill a patch and sand it flush, a coat of paint is most likely going to reveal a "dish" sanded into the soft masonite. If you try the repair, do not sand with a power tool, but use sand paper wrapped around a nice flat piece of wood, and sand with very light pressure and long strokes to prevent digging in a small area.
