Fix For Warped 6 Panel Doors? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-04-2007, 12:46 PM   #1
Fix for warped 6 panel doors?
I have a house that was built in the 50's. It has 6 panel pine doors (painted) in the upstairs that are not original to the house. The top edges are not painted. The problem is that they are warped, and the bottom edge of the door hit the door stop about an inch before the top does. Is there a way to fix this, or would it be easier to buy a door blank and start over. Thanks, Mike
Mikon is offline   Reply With Quote
Old 10-04-2007, 02:49 PM   #2
Rewards Points: 1,910
Are you sure the door is warped? This often happens if the door frame is installed wrong or if the hinges aren't aligned properly. Check the doors with a straight edge before you do anything.
Old 10-04-2007, 04:12 PM   #3
Rewards Points: 264
You can check if the door is straight with a string running along the edge of the door.
If it's warped, you can adjust the stop trim accordingly.
Remove the stop trim, close the door and reference where the edge of the door is to the jamb. Install the stop trim to make up for the warpage.
Or...just buy a new door.
Jeekinz is offline   Reply With Quote
Old 10-04-2007, 04:20 PM   #4
Thanks for the input, I checked the doors with a plumb bob, and the worst door is about 3/4"-7/8" out of plumb, with the strike edge of the door being the worst. Why would they warp so badly?
Old 10-04-2007, 04:40 PM   #5
Rewards Points: 264
Age, poor materials. An apartment I used to live in had the same problem. The stop trim will bend enough to compensate. Just get a new length of it, it's pretty fragile, the old piece will probobly break when removing it.
Old 10-04-2007, 04:46 PM   #6
Out of plumb is not warped!!! Check with a straight edge to see if they are warped or, as I suspect hung out of plumb.
Old 10-04-2007, 06:31 PM   #7
Couldn't mikon use the plumb bob on the hinged side of door to tell. It should follow the string all the way down there, and then when you slide it to the outside edge of the door...it should be the same.
I'm sure he has already done this
97catintenn is offline   Reply With Quote
Old 10-04-2007, 06:43 PM   #8
Jogr,
I think I'm missing the point of what you mean by using a straight edge. I don't have a straight edge the length of the door, only a 4' level. That's why I used the plumb bob on the face of the door, (not the edge). On the hinge side the string stays true to the door face all the way down. On the strike side, the string is touching the face at the top and leaves a 3/4" gap on the bottom. If I'm missing the boat, let me know. Otherwise, I'll do as the others have suggested and install new door stops. Thanks, Mike
Old 10-05-2007, 10:02 AM   #9
Rewards Points: 264
I would remove the upper and strike side stops, then close the door and mark around the edge of the door onto the jamb with a pencil. Install new stops accordingly. Either the top is bowed or the bottom....or both. Closing the door first will ensure proper alignment of the stops.
Old 10-05-2007, 10:06 AM   #10
Good idea, using the plumb that way is even better than a straight edge. And you are right they are warped. Try the trim stop adjustment on one door as others suggested. 3/4" adjustment is quite a bit and may not look as good as you want. If not, then new doors.
Old 10-05-2007, 10:14 AM   #11
Rewards Points: 264
If the top and bottom are out, a plumb line will show exaggerated results. i.e. The door is out 1/2" on the top and 1/2" on the bottom, the plumb line will show 1" out on the bottom.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Attic Doors cyepsen Building & Construction 3 06-24-2007 07:47 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
