Fix Deck Structure Or Tear It Down? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 01:03 AM   #1
Fix Deck Structure or Tear it down?
My plan is to try to save the structure and support posts of my deck, but replace the decking and railings. This is a raised 12 x 20 deck in fair condition, about 14 years old. Decking needs replacement, and guardrails are not built properly.
BUT: The 4x6 posts are NOTCHED so the rim joists sit on a notched post.
A couple of the posts show cracks where they miscut the notch. Worse, they used undersized lag bolts which are getting pulled at an angle from the load, and one post is bowing since the rim joist is not tight against the post.
My plan is this:
If I tear off the decking and railing, and put temporary supports under the structure, I could then add an additional 2x12 rim joist and cut the top of the 4x6 flush get rid of the notch on top of the 4x6 posts (see attached jpg).
Is this logical or not?
Robo_geek is offline   Reply With Quote
Old 05-01-2011, 07:26 AM   #2
Rewards Points: 5,336
As long as the support part of the post is still structural, it should be fine.
Ron
Old 05-01-2011, 11:37 AM   #3
Thanks, I appreciate it.
Old 05-14-2011, 10:30 PM   #4
Rewards Points: 212
It looks fine, just add more bolts or larger lags
bluebird5 is offline   Reply With Quote
Old 05-15-2011, 08:29 AM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Are the posts that you want to cut doubling as the newels?
How do you intend to connect the new newel posts?
I don't like the plan right now but there is not enough info to be sure.
Andy.
AndyGump is offline   Reply With Quote
Old 05-15-2011, 08:56 PM   #6
Andy.
If I were to try to save the structure, the posts would be 4x4 carriage-bolted to rim joists.
At this point I'm thinking that the whole structure has to go....I'm going to call around for some quotes. The more I look at the structure, the more things I see wrong. The stairs, for example, are really done poorly. Thanks for the feedback.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
Deck structure question houseinthewoods Building & Construction 5 06-13-2010 09:18 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
