Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-14-2009, 01:33 PM   #1
Fitting a speed bag
Just got my speed bad today and dont have the slightest clue about the fittings. it says this platform has been specially designed to fasten to 16" on center wood wall studs and if you have wood wall studs plan use 1/4" x 1 3/4" lag bolts ( not supplied )
Is it true that I may need to put two pecies of wood horizontally against the wall studs and then the actual mount for the speed bag screwed or bolted to that wood.
It also says if I dont mount the platform on 16" or center wood wall studs then to consult my local hardware dealer to procure suitable fastening devices...does anybody no any other way which may be easier for someone who hasn't the slightest clue?
anything i should watch out for ?
please help
Also in the Uk
murad009 is offline   Reply With Quote
Old 11-14-2009, 01:59 PM   #2
Tool Geek
PaliBob's Avatar
Fitting a speed bag
Murad in the UK, Welcome to the Forum
Is this the model that you have?
& Stay Safe
.....Bob Lavery
Old 11-14-2009, 06:06 PM   #3
Fitting a speed bag
Hey, thanks for the reply it is Everlast and adjustable but the mounts are a little different.
Old 11-15-2009, 05:27 AM   #4
Tool Geek
PaliBob's Avatar
Fitting a speed bag
Originally Posted by murad009 View Post
....Is it true that I may need to put two pieces of wood horizontally against the wall studs and then the actual mount for the speed bag screwed or bolted to that wood.
That is the method I would use because while you guys started all that 16" business that we still use, It is not a standard that is absolute. In framing a wall an instance of >16" spacing may be rare (except for metric 50cm of 19.7") but the actual spacing may be less in some of the stud bays in a typical wall due to physical layout. The bottom line on both sides of the pond is that 16" stud spacing can never counted on as a standard for mounting anything heavy.
.......anything i should watch out for ? ....
Yes, Utilities e.g. Water, Electric, Gas, Drains, & HVAC.
Use a 6d nail to find the center of the stud even if you use a stud finder. Stud Finders are not entirely reliable due to the wide variations in finish materials. You will end up with a row of small exploratory nail holes but this can be filled with Spackle from the local DIY store.
Hope this helps,
& Stay Safe
.....Bob Lavery
Old 11-15-2009, 12:10 PM   #5
Fitting a speed bag
Thanks for that.
Old 11-15-2009, 01:01 PM   #6
Fitting a speed bag
Oh yeah, What would you recommend, the two vertical strips of wood underneath the speed bag mount or three horizontal strips spaced out equally.
the speed bag is going to be fitted in my bedroom
just need to get the lag bolts and wood tomorrow
Old 11-15-2009, 04:18 PM   #7
Tool Geek
PaliBob's Avatar
Fitting a speed bag
Mount the backer boards Horizontal
On the wall pencil a horizontal line at a height from the floor that corresponds to the ℄ of the middle backer board then mark the stud locations along this line. That way any marks or nail holes will be covered by the backer board.
& Stay Safe
.....Bob Lavery
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 10:54 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 04:12 PM
Two Speed Compressors rjordan392 HVAC 2 08-26-2007 02:32 AM
