Fitting New Wooden Door With Two Locks - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-20-2016, 07:02 AM   #1
Rewards Points: 4
Fitting new wooden door with two locks
At present there is a not very wide UPVC old door.
Can you remove the door and frame, install a new wooden frame with new 44mm wooden front door. Then install any old 5-lever mortice lock plus a latch which covers various thicknesses?
Thank you
graemeb is offline   Reply With Quote
Old 10-20-2016, 07:33 AM   #2
joed's Avatar
Rewards Points: 12,892
Re: Fitting new wooden door with two locks
Sounds like something that should be possible. Most lock sets can adapt to different thickness of doors.
Old 10-20-2016, 07:57 AM   #3
Rewards Points: 3,837
Mortise style locks require the removal of a lot of the door stile. You might get away with it using a solid door.
Why do you want to use an old lock style?
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 10-20-2016, 10:56 AM   #4
Rewards Points: 4
Thank you. Mortice is UK standard. The frame/door is old so new one with wooden would be good. Then can have two locks not just a single key for UPVC.
Compression Fitting Leak ulrichfolkers HVAC 24 09-03-2014 08:15 AM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
Fitting wooden door saddles RDS Flooring 3 11-06-2009 06:37 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
