First Timer On Trim, Need Some Tips. - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 08:06 AM   #1
First timer on Trim, need some tips.
Hello,
As the title states, i'm a newbie attempting trimwork.
Here's a short story,
Me and my buddy did some small reno's to my newly acquired condo, we did ceramic tiles and bamboo floors as our initiation to renovation.
Now that the floors are done, i'm trying to decide on what to do with my casings.
I have attached pictures of one casing that i've tried with two different style of header (the top part of the casing). And to be honest, none of them work for me. I'm trying to go for a modern style of trim, with clean lines, and cuting the casing at 45 degre angle is not really my style.
Maybe you guys can shimme in and give me some input. Right now i'm thinking of putting a large and flat piece on the top of the door casing.
1st pic - Plinth block with casing, and a mock up piece of casing as a baseboard to give the intended look. The baseboard is the same style, except 2 inches higher. Just give an example.
2nd pic, what it looks from far back.
3rd pic, up closer, it look weird where where the horizontal meets the vertical piece. Again, not looking at making a 45 degree cut.
4th pic, i flipped the top piece, again, this looks odd to me.
Other option that i'm considering is the following.
https://elitetrimworks.com/skin1/ima...ed_casings.jpg
or maybe just a flat piece of mdf,
What would you guys recommend.
Thanks again.
Syl
laflsyl10 is offline   Reply With Quote
Old 01-25-2012, 09:12 AM   #2
Old School
Willie T's Avatar
Because you have a "profile" (curved and notched shapes) to the molding, it really needs to be cut at 45 to look right.
Willie T
Old 01-25-2012, 11:27 AM   #3
Try using simple, square corner blocks at the upper corners. No, I don't mean rosettes. I have seen perfectly plain with 45 edges.
QUEENQUITETALOT is offline   Reply With Quote
Old 01-25-2012, 12:12 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
You may want to bevel the inside of your plinths, the door could hit the edge of them if opened too far.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-25-2012, 01:08 PM   #5
MarginallyQualified
Rewards Points: 2,464
You do trim like I do it.
I'd use fluted pieces for the vertical and horizontal...
a plinth block that was larger than the fluted pieces...
with rosettes at the top corners.
Old 01-25-2012, 02:48 PM   #6
Thanks for the response, i'll try some trials tonight and get back on here tomorrow.
Old 01-25-2012, 06:21 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
for picture 1: the proportions dont really work for the plinth block and baseboard in comparison to teh casing. i always use a baseboard that is 2" wider/ taller than the casing. from there the plinth block should be 1" taller than the base
picture 2: having the header casing sitting on top of the legs that way looks terrible, never butt a molding to itself so the profile doesnt smootly flow around the door frame
picture 3: for a boston header same rule applies as to what i mentioned for #1 for the proportions to look correct the header should be atleast 1 1/2- 2 " taller than the width of the casing.. meaning 3" casing with a 5 " header
heres some examples from my portfolio
First timer on Trim, need some tips.-n1254467715_30371344_7339424.jpg   First timer on Trim, need some tips.-hanson1.jpg   First timer on Trim, need some tips.-oakland5.jpg   First timer on Trim, need some tips.-headertrim.jpg
woodworkbykirk is offline   Reply With Quote
Old 01-25-2012, 06:39 PM   #8
Rewards Points: 13,994
Looks like your trying to use beaded baseboard for casing.
Go buy a Starrett 505 mitre guage. Perfect mitres every time.
Any time your trying to do a 45% at the top of a casing you need to make that joint first. Attach the top piece first, then attach the sides by nailing from the top and sides, then the jamb to casing area. This will hold the top joint area tight and allow you to move the casing from side to side to hold it for an equal exposure.
Old 01-26-2012, 10:49 AM   #9
Thank you for your reply, very intersting post.
In my picture # 1 you guys seem to have misinterpreted what i was trying to show.
I'm using the same moulding, in this case the casing, on the casing and on the baseboard. But only to show what i was trying to get to. I have the baseboard at home, it is 2 inches taller than the casing that i was making a mock up off.
You guys can see it at this page 13 of the book, the style is ZEN
http://www.classicwoodmouldings.com/...OTT_Retail.pdf
As for the casing itself, it is only held in place by a few nails, and i did install it from top to bottom, but i just posted the image in a difference sequence. I'm still new to this, so i was looking for inputs on headers.
Your image are very helpful.
Old 01-26-2012, 01:20 PM   #10
I was thinking the same.
jasin is offline   Reply With Quote
Old 01-26-2012, 01:24 PM   #11
Where the top trim joins here at the top http://www.diychatroom.com/attachmen...ps-hanson1.jpg no offense, but that does not look right to me.
Here's a video on How To Cut Inside Corners
http://www.videojug.com/film/how-to-...creative-crown
Hardi Board Trim installation tips?? JulesB Building & Construction 8 03-24-2011 08:05 PM
Recessed Light Trim not flush - tips? sctazmon Electrical 8 10-11-2010 08:20 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Hung my plasma...1st timer tips... Bacardi 151 Home Theater 15 01-03-2008 02:23 AM
tips for caulking trim?? shotdown Painting 2 08-15-2007 11:37 PM
