First Hardwood Floor Installation - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 01:20 PM   #1
First hardwood floor installation
I've got a 24' by 24' square room. We've got a local miller cutting 5" hickory T&G 9 foot boards.
Some questions I have are : the cupping issue. I (think) i have to use an under layment (Black Jack) because my floor sits 24 to 30 inches above the ground and moisture could be an issue (live in the south, not coastal). I can't glue with an under layment and didn't know if cupping would eventually be a problem.
2. The ends of our boards will not be T&G. I was told I could face nail the ends or even use plugs. Which is better? and will it be sufficient?
3. I'm renting a pneumatic floor nailer but have a 15G finish nailer. Will the 15G be able to do the places where the floor nailer can't reach (beginning and end) or do I need to predrill and hammer those places).
Some info on my floor: I have 3/4" CDX subfloor over 2 by 8 joists 22" spacing with a 11.5' span. It's an old house we completely remodeled and the CDX sits on top of 3/4" old subfloor. In other words a 2" nail will barely touch my joists. Is this a problem? Do I need longer nails?
Any other suggestions would be greatly appreciated.
freemike11 is offline   Reply With Quote
Old 07-26-2011, 01:28 PM   #2
Rewards Points: 5,336
What is the(will be) the moisture content of these floor boards once you get them?
With a 5" board, I can't see it staying in place without both nails and adhesive.
I see no issue with the thick subfloor and the nails just in that.
Ron
B. Franklin 1759
Old 07-26-2011, 05:26 PM   #3
Kiln dried. Should be no moisture.
Old 07-27-2011, 07:01 AM   #4
DIY staff
Rewards Points: 7,174
You could add your own tongue and groove using a router---that would be faster and better than face nailing and filling every board.
Old 07-27-2011, 08:10 AM   #5
My question would be, why can't a flooring manufacturer do the whole job to begin with?
Ron
B. Franklin 1759
Old 07-27-2011, 08:28 AM   #6
DIY staff
I wondered that myself-----
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 01:45 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
