Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-01-2007, 08:07 AM   #1
Firewood rack
anyone have a good idea to build a inexpensive firewood rack to keep wood off the ground? say 10 long 4 foot wide? thanks
econdave is offline   Reply With Quote
Old 03-01-2007, 08:57 AM   #2
Darylh's Avatar
Firewood rack
Pick yourself up some wood pallets and landscape ties. Place the ties so they are the same width as the pallets put a hole in each end and drive a piece of Rebar through the tie and into the ground and then just lay the pallets on top and your good to go.
Darylh is offline   Reply With Quote
Old 03-01-2007, 04:10 PM   #3
Firewood rack
We picked up 4 pallets and 4 T-posts [farmers use these a lot to string barbed wire.]
We laid 2 of the pallets side by side and put the T-posts into the ground at each outside corner. Then we dropped one pallet on its end over the T on one end and the other pallet on its end over the T post on the other end.
Basically you have a great big |_| keeping the firewood off the ground and keep it corralled between the two upright pallets. Total cost about $10.
shapeshifter is offline   Reply With Quote
best way to season firewood? elementx440 HVAC 4 04-16-2007 12:53 PM
Dishwasher - top rack no water pressure jbomber Appliances 5 12-18-2006 05:49 PM
