Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-11-2006, 01:52 PM   #1
nat
Smile
Fireplace "heatilator"
My house has a fireplace with a heatilator from approx. 50 years ago. Fireplace is brick with 4 heatilator grill vents on the front. They are pretty unattractive. It is doubtful that the heatilator even works anymore. I was told that I could just shut off the heatilator fan and cover the vents (they are cut into the brick). Cover with lumber tile, granite etc to make a more attractive fireplace.
Has anyone done this or know anything about doing it??
nat is offline   Reply With Quote
Old 11-11-2006, 05:16 PM   #2
General Contractor
joasis's Avatar
I was thinking about installing a heatilator in the new home we are planning, and the masonry guys discouraged me from doing this. I will see if I can get a few of them to pop over and look at your post and give you some advice.
joasis is offline   Reply With Quote
Old 11-11-2006, 06:56 PM   #3
nat
Thanks.. I'd really appreciate that!
Old 11-17-2006, 03:04 PM   #4
HarryHarley
HarryHarley's Avatar
Nat, I have a Heatilator thats 25 years old. Had it inspected and has no problems. As long as you don't ever plan to use the fireplace any more you can cover the vents with your desire. But, the vents circulate heat around the back of firebox. If you or a future user of wanting to use it again, covering it would be dangerous.
HarryHarley is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
Gas Fireplace ChrisSensabaugh HVAC 3 07-31-2007 07:08 PM
huge fireplace issues krynstar Painting 10 03-10-2007 07:41 PM
Fireplace leaking mmcginn2 Roofing 4 04-23-2006 11:12 AM
Water leaking over fireplace mmcginn2 General Discussion 1 04-21-2006 12:42 AM
