Fireplace Enclosure - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-08-2015, 05:22 PM   #1
Fireplace enclosure
Moved in to a house last year and it has a fireplace enclosure on outside of the house they used cheap plywood barn siding and need to replace what is the best replacement material to use in it place. A rot resistant material and should it be plywood then a house wrap and then a exterior siding.
aircore is offline   Reply With Quote
Old 09-09-2015, 06:30 AM   #2
Rewards Points: 3,839
I suspect that using whatever is on the rest of the house would look best. Plywood or OSB then a house wrap and then a exterior siding.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 09-09-2015, 09:31 AM   #3
Rewards Points: 5,336
I guess that depends on your budget and your taste. Once you get past the basic construction already mentioned, the finish materials are numerous.
Do you want the fireplace to blend into the house or do you want to be a focal point?
Ron
B. Franklin 1759
Old 09-10-2015, 11:48 AM   #4
I need to reside the hole house but can't at this time so in the mean time need to tear off what is on there and replace with something it roted and bees are making a home in it.
Trying to troubleshoot a gas fireplace, need help glenh Appliances 3 11-03-2013 06:48 AM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 08:09 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
