Fire Stop ? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 06:21 PM   #16
Old School
Willie T's Avatar
You haven't read this, have you?
This may help as well.
How to fireblock framing
DM
Probably the best article I've ever seen written on fire blocking.
Willie T
Old 03-04-2011, 08:32 PM   #17
Registered User
Rewards Points: 5,204
In your 8' high wall, every 10' lineally, f.b. is required. Ask your local B.D. as foam on the concrete may not be acceptable without wood from stud/concrete with a v.b. plastic; #7 here: http://publicecodes.citation.com/ico...9_3_sec017.htm
Gary
Old 03-05-2011, 11:59 PM   #18
Originally Posted by griffinst View Post
I'm doing this because foundation walls are not completely square. Mine are pretty close but I want it as close to exact as possible. My room is 40' long so a slight variation would end up showing itself pretty quickly. I used the 3-4-5 method to square up my chalk lines.
use fire resistant plywood not as heavy as drywall,then fire caulk,i use lasers in my basements the tasks of snaping lines are cutt in half not needed in other words,difinitly worth the money.GL
Stainless steel is offline   Reply With Quote
Old 03-10-2011, 09:16 PM   #19
Registered User
Termite's Avatar
Thanks WillieT. The answers are all there.
Old 03-10-2011, 09:21 PM   #20
Registered User
Termite's Avatar
Although it would work the code makes no provision for FRT plywood in fireblocking applications. It simply requires 3/4" structural panels, so technically 1/2" and 5/8" FRT plywood do not meet the letter of the code.
Not to mention their price.
Fire caulk is also unnecessary in fireblocking, albeit effective. Fireblocking foam is an easier and much cheaper alternative.
Old 04-27-2011, 12:52 AM   #21
Rewards Points: 172
I would never have read or even thought about the subject if you didn't post that link. Well, I guess I THOUGHT about it. That's why I'm in this thread.
nateshirk is offline   Reply With Quote
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Fire Stop jamiedolan Remodeling 7 03-03-2009 12:39 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
