Fire Door In Existing Wall, Bedroom To Garage? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 08:37 PM   #1
Fire door in existing wall, bedroom to garage?
Hi y'all,
I need to put a fire door in an existing wall separating a garage from a bedroom. The garage side of the wall is stucco, the interior is drywall. My main concern right now is making sure I install it correctly to keep the fire rating intact. Do I need to put in extra insulation around the door?
I'm going to use a pre-hung 90 min fire rated door, but i'm going to have to move some studs around, put a header in, and all that in the existing wall. I have never done this before. Words of wisdom, advice, necessary things I must do with out fail? This is all happening in SoCal.
Azul is offline   Reply With Quote
Old 01-31-2013, 07:22 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
your not allowed to have a doorway going from a bedroom directly into a garage as per fire code..
woodworkbykirk is offline   Reply With Quote
Old 02-01-2013, 06:03 PM   #3
Oh, we'll so much for that.
So, there is another wall I could use from the garage to the laundry room. Its a clean wall, the dryer and washer are on the oppesite side, just won't be as convienient. Same questions apply.
Old 02-01-2013, 06:32 PM   #4
Rewards Points: 6,652
Actually it no longer becomes a bedroom, but a living or working area. Plus you have to remove the closet doors.
Old 02-01-2013, 06:50 PM   #5
your right greg.. as long as the room isnt a bedroom your fine... as stated for fire reasons and fumes
Old 02-01-2013, 07:36 PM   #6
Friends had to do that for one room, like the Op is wanting to do. Funny thing is, Iowa taxes by the bedroom, and right now it is used as a guest room/office space, so they got under the radar on it.
Old 02-01-2013, 07:38 PM   #7
Just do both, and also check with your local taxing authority, is tey do as I stated with friends of ours in Iowa, which taxes you by the number of physical finished sleeping areas in the structure.
Old 02-01-2013, 08:32 PM   #8
Sweet! Thanks everyone for all the great info. I'll stick with my original plan first. The "bedroom" will not actually be used as a bedroom any way. So, about actually building it...?
Old 02-01-2013, 11:12 PM   #9
GBrackins's Avatar
Rewards Points: 2,108
typically a fire rated door from garage to interior space must be either a 20-minute rated door or a minimum 1-3/8" solid core.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-01-2013, 11:14 PM   #10
Depends on the area. Some require a min. 2 hour burn for the door. 20 min is nothing, when you actually think about it.
To add, anyone with a older style smoke detector, not a photo-cell type, it can take at least 35 min's before you are aware that a fire is happening somewhere in the home, if it is smoldering, and not raging. Even if it is raging, it can take 17 min's max, before the older style detectors go off.
The Following User Says Thank You to gregzoll For This Useful Post:
GBrackins (02-01-2013)
Old 02-01-2013, 11:20 PM   #11
GBrackins's Avatar
true, I was providing the 2009 International Residential Code requirement, as it only requires 1/2" drywall on the wall to separate the garage from living space.
R302.5.1 Opening protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 13⁄8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 13⁄8 inches (35 mm) thick, or 20-minute fire-rated doors.
gregzoll is correct, best to check with local authorities
Gary
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
HVAC duct through a fire rated wall elmaur Building & Construction 2 05-30-2011 12:22 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 09:03 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
wiring from existing panel to new garage al99m Electrical 8 07-29-2009 08:42 PM
