Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-08-2008, 01:48 PM   #1
Default Finishing nailer vs. clipped head and framing nailer
I am about to build a lean to shed in the rear of my home. I will build three sides and use the existing brick fascade of the house for the rear. Using 2X4's and perhaps cedar planks for siding can I use a finishing nailer? I have a Dewalt D51275 nailer but its for finishing nails. I'm aware that it would not meet local building code. Thanks...........Woody
harwoodb is offline   Reply With Quote
Old 10-08-2008, 01:51 PM   #2
Those finishing nails would not have any holding power for a lean to anything. I bought myself a Senco Pro 602 Framing gun from lowes and havent regretted it yet. If all I was going to do was build a lean to, I would just use a hammer
on second thought... knowing what i know about a framing gun... I would buy the gun.
rustic is offline   Reply With Quote
Old 10-08-2008, 02:14 PM   #3
Keep in mind that modern construction depends on several things to make something solid. Sheeting on a building is integral to the strength and needs at least 12d nails to help keep the 2x4's in place.
But once that is done you can use anything you want to to nail on the siding. Keep in mind that wood is dynamic meaning that it is always flexing, expanding, contracting, twisting and so on. Things like sudden pressure gradient changes and aerodynamics can cause damage. Extreme examples of this are tornados (massive pressure change) and hurricanes (aerodynamics). But even a 30 mph wind can cause a small building to come up off the foundation if it is designed so that there is lower pressure on the top versus inside pressure and the building is not secured to the ground.
I have found that information dictates correct procedures.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-08-2008, 04:37 PM   #4
Drywall contractor
I'd spring for the framing nailer, but I don't need much of an excuse to buy tools..... Harbor Freight has them pretty cheap when they're on sale (harborfreight.com if you don't have a retail store locally). I can't vouch for the quality of the tools (made in China mostly), but for an occasional user it may be ok. They are warranted so you could return it if its a piece of junk. A quality framer is in the $225 -$300 range at HD or Lowes. (The best way to go.) Or you could opt to "hand bang" as rustic suggested. Definitely use framing nails!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-08-2008, 06:37 PM   #5
Thanks, I went for the pnematic heavy duty palm nailer , and the round type nails since I will be using angle braces, contractor friend of mine suggested it . I'm quick to buy the tools also, but Ihave a real nice Dewalt trim nailer and have run out of projects where I am likely to use the larger framing nailer. Hate to drop a couple of hundred dollars for a tool I will only use once. Usually end up loaning things to the neighbors. I havent used the galvenized angle supports but they look easy enough. Know what I mean, you see them often used instead of toe nailing 2x4's they have them in a variety of angles.
Old 10-08-2008, 06:57 PM   #6
Drywall contractor
Understand completely..... in this day and time, it's hard to spend on things other than necessities. And again I really hate to even suggest the "China Freight" gun, but it might do for occasional use. Sounds like you came up with a good plan. You can always "tack" things together with a couple of trim nails then use your brackets and palm nailer for the final install. (Could use screws for that matter, if you're using brackets.) Best of luck.
More On This Topic
Hi, this is John on behalf of Expert Village. In this video clip I'll be talking about the tool specs for brad nailers. When you get ready to use a brad nailer you always want to reference the tool specifications and the nail specifications. This is... Read More »
Pinning with a Nail Gun
Pinning with a Nail Gun by Expert Village
This is Rob McManhon for Expert Village. One method that is good to know with a framing nailer is pinning. This is something that you would use if you were building a header for example. Now a header generally for 2x4 wall would be whatever the... Read More »
Hi! I'm Tim Eaton on behalf of Expert Village. So we got our piece cut 13 inches and the next step would be to install it and basically anytime your are doing work with 2X4s fence unless you are actually replacing fence board you want to use a 12D nail... Read More »
Hi, this is John on behalf of Expert Village. In this video clip I'll be talking about basic safety instructions. First off make sure you're wearing Z87 approved safety glasses. When you do discharge the nailer, there will be a burst of air that will... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be showing you how to properly set your pressure. Here I have a piece of oak, oak is a very hard wood. When we put our brads in, we want them to sink just below the surface. We don't... Read More »
Clipped Head v. Full Round Head Nails RickT Carpentry 4 11-19-2009 12:45 AM
what type compressor for framing nailer drewhart Tools 4 07-27-2008 03:17 PM
$150.00 for Milwaukee Round Head 2-to 3-1/2-Inch Framing Nailer jelly Building & Construction 3 06-02-2008 08:30 AM
clipped FINISH vs. FRAMING nail amakarevic Building & Construction 4 04-25-2008 05:46 PM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 08:43 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
