-   -   Finishing nail removal (http://www.diychatroom.com/f14/finishing-nail-removal-2028/)
bklauer 03-12-2006 03:06 PM
Does anyone know how to remove finishing nails? I am trying to remove finishing nails from the bedposts of a salvaged bed frame. Someone used the finishing nails to try to keep the bed frame together. The nails are sunk into the post and I have no idea how to remove them without damage. Any ideas? Thanks!
joed 03-12-2006 04:29 PM
Are they sticking out? If so just grab them and pull out with a hammer. Use a thin piece of wood as protection between the hammer and the bed post.
MinConst 03-12-2006 10:11 PM
If the bed is apart pull them right through. If you pull them out the way they went in you will damage the wood. It is best to pull them through.
Mike Swearingen 03-13-2006 09:32 AM
You also can use a small straight-shank punch the same size as the finish nailhead to drive them through.
Mike
boman47k 08-29-2006 07:52 PM
If they were made accessible, could they not be cut and ground down flush and th eheads counter punched and puttied then use another method of repairing the bed? According to where the nails are, I would be a little concerned about splitting some wood on the bed by pulling the heads through. If this makes no sense, ignore it. I have dealt in antiques a little and am new on this board, reading some of the posts, and just getting my feet wet...so to speak.
MinConst 08-30-2006 07:52 PM
Hi Boman47,
This is an old post so I'm sure they have solved the problem. But finishing nails have no real heads. Pulling them through will not damage the face of the wood like extracting them can. When you extract a finishing nail you run the risk of chipping the face a bit.
Welcome aboard.
boman47k 09-05-2006 07:13 AM
Maybe not real FLAT heads commonly thought of as heads, but they still have the wider part on the end. Guess I was thinking of really old, dried and small wood with big finishing nails used to repair.
