Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-15-2007, 12:16 PM   #1
Default finishing exterior
Hey everyone, I am currently starting up a project that I left off on last fall due to the weather. I am setting a pre-fab house on a daylight foundation. I used ICFs for the foundation and plan to continue covering the rest of the house with 2 inch foam. Once I am finished I plan to use a stucco or drivet type finish on the house.
I am looking to gather some ideas on what would be the best way to finish out around my windows that are currently on the house. Would it be best to reset them to the outside of the insulation or could I leave them where the are, just fur them out and have a two inch "shelf" around them? I thought this shelf might work considering the type of finish I am planning to use.
By the way, great site!
lionhntr is offline   Reply With Quote
More On This Topic
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be formulating a plan. In the room where our bookshelf is going to go, we have a window and below the window we are going to have our bookshelf in it. Now the width of our unit is... Read More »
Some people discover quite a mess in cabinets and drawers when they move or do spring cleaning. However, shelf liner catches it all; that's the purpose. The type of shelf liner you buy to place in your cabinets and drawers depends on your needs and how... Read More »
How to Load a Pottery Kiln
How to Load a Pottery Kiln by Expert Village
Hi I'm Jen from Clay Cafe and on behalf of Expert Village, I'll be showing you how to take your ceramic piece from start to finish. In this clip I am going to give you a couple tips on how to load your kiln. There's a couple things to remember when you... Read More »
Resilient Channels and finishing drywall Pat the Dad Building & Construction 5 06-08-2007 10:32 AM
Interior vs. exterior paint KCnorthernCA Painting 2 10-09-2006 08:01 AM
Finishing nail removal bklauer Carpentry 6 09-05-2006 09:13 AM
exterior paint question sherlock Painting 5 07-05-2006 09:31 AM
Pressure Washing and other EXterior prep work CGofMP Painting 0 07-15-2005 12:39 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
