Finishing DensArmor - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 09:48 AM   #1
Finishing DensArmor
I have read alot about finishing DensArmor. Many of these 'conversations' on different chat boards are a few years old.
I am considering using DensArmor in my basement project - just a 12X12 mud room with a stairway. I DryLocked the concrete walls prior to framing and of course used PT sills.
What I gather is using DensArmor, the overall consensus is wear a mask as the fiberglass gets into the air and use nylon tape verus paper.
The questions I have is... what about joint compound? In my upstairs, I previously used Durabond 90 (lightweight) dry compound and used the corresponding ready mix lightweight (blue versus green can) compound. Is that what I should use in the basement as well?
Also... am I going to end up having to skim the entire surface to make up for the slight texture? Is there a special paint or something that can help out with the texture issue?
One message board suggested using a 3/8 roller and rolling onto the wall a real wet coat of joint compound and skimming that with an 8" blade - this a good idea?
I know... lots of Qs all over the place...
Thanks !
dhcoupons is offline   Reply With Quote
Old 02-10-2009, 07:54 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Use USGs Densarmor cote compound. It doesn't have any organics in it for mold food.
Old 02-11-2009, 01:55 AM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
Ditto, for compound use GP's DensArmor Cote. It can be found at Lowes (most of them anyway). Use fiberglass tape.
If you prime the DensArmor with a 1/2" or 3/4" nap roller, the final paint coat will look the same as regular drywall.
Definitely wear gloves when handling/cutting the DensArmor. It's actually worse than messing with fiberglass batt insulation.
DensArmor is a great product. I use it in all bathrooms I remodel.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-11-2009, 06:28 AM   #4
Sorry........ GPs, not USGs. My bad.
Finishing a Basement Window Dan OBrien Carpentry 3 01-04-2009 08:56 AM
Finishing nailer vs. clipped head and framing nailer harwoodb Carpentry 5 10-08-2008 04:57 PM
Resilient Channels and finishing drywall 9728 Building & Construction 5 06-08-2007 08:32 AM
drywall finishing BOP101 Building & Construction 3 10-07-2006 08:31 PM
Finishing nail removal bklauer Carpentry 6 09-05-2006 07:13 AM
