Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-08-2008, 03:17 PM   #1
finishing around a window opening
i framed in some rooms of a stucco house. this made the distance from the wall to the window deaper. i want to finish this surface with some wood like poplar, but its kind of expensive. is there any other kind of wood suitable for this purpose that is cheaper and wheres a good place to get it? also how do i make the window sill on the bottom? do i just use some 3/4" poplar or something and round the edge off with a router?
drewhart is offline   Reply With Quote
Old 11-08-2008, 04:22 PM   #2
Moderator
Termite's Avatar
As hardwoods go, poplar is very inexpensive. It is the best wood for painted applications in my opinion.
What I think you're talking about is a jamb extension, which extends the window frame to the face of the interior wall. They're typically built with pocket screws and joined to the window frame with biscuits. The window's casing covers part of the edge of the jamb extension for a nice detail. The sill is built from 3/4" poplar as well, and serves as the jamb extension at the bottom.
You really need to pick up a book on trimwork to understand how to do all this. It is too complicated a process to adequately describe online without pictures.
Old 11-08-2008, 04:27 PM   #3
yeah like a jamb extension.
Old 11-08-2008, 07:28 PM   #4
Custom Cabinet Maker
KC got it.
Poplar is the least expensive wood,and best for this purpose. It is the softest of the hardwoods :}:}. Fantastic paint grade lumber,easy working.
skymaster is offline   Reply With Quote
Old 11-08-2008, 07:58 PM   #5
Man of many hats
wrangler's Avatar
Originally Posted by skymaster View Post
KC got it.
Must be the availability (or lack there of) that makes poplar more expensive down here than clear pine or fir even.
Man of many hats
wrangler is offline   Reply With Quote
Old 11-08-2008, 10:44 PM   #6
WOW maybe we can swap some junky ole poplar for some of that cheap ole clear fir LOL LOL.
Where bouts on da handle? Got a friend in Ft Walton beach
Old 11-09-2008, 09:50 PM   #7
what if i finished this area with drywall?
Old 11-09-2008, 10:50 PM   #8
That is very doable. Tho IMHO no class LOL
Old 11-09-2008, 11:00 PM   #9
yeah it seems crappy.
Old 11-10-2008, 07:09 AM   #10
Man of many hats
wrangler's Avatar
That's very common and not hard to do if you dont mind working with corner bead, but still do the stool/sill with either stool stock or like you said, make on from poplar or pine and then add a skirt to the underside.
Man of many hats
Old 11-10-2008, 12:01 PM   #11
Drewhart. Truth be said it is easier to do it in wood. by the time you rock it, bead it, 3 coats of spackle and sand I would be sitting on the deck drinkin sweet tea and eatin ribs just watchin ya workin LOL LOL.
Whole deal should cost ya less than 50 bucks in wood to start with. Take some pics. 4 ext jambs, 3 pcs casing, one pc stoll and one pc apron, should take no more than an hr or hr and half.
Jack
Old 11-10-2008, 12:34 PM   #12
the Musigician
DangerMouse's Avatar
heck, if poplar was good enough for Leonardo to paint on.......
(Mona Lisa is painted on a poplar panel)
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-10-2008, 01:00 PM   #13
DM; Does that mean the real reason she was popular was the fact that she was on poplar or was she just pine ing for Leonardo? Also we also know she was really a beech
Old 11-10-2008, 01:52 PM   #14
the Musigician
you bet your sweet ash she was! i birch you took a lot of thyme to think of all those plant puns.... let's leaf this joke go now.....
DM
Old 11-11-2008, 10:26 AM   #15
I have NEVER seen wood stand up to this application for LONG TERM, goof proof solutions. IF I were using wood it would be oak,period,,,BUT,,,if you have vinyl windows, why not continue in with vinyl,pvc extensions so they last and are finished for 'life'. Course I may not live long any more!!
4just1don is offline   Reply With Quote
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 09:14 PM
Cut window opening in concrete foundation. Bcoleman6 Building & Construction 2 03-10-2008 07:38 PM
creating a basement window opening in a brick wall amakarevic Building & Construction 5 01-30-2008 12:06 PM
