Finished My Router Table - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 04-12-2011, 04:54 PM   #1
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Finally. It took about 4 weeks, working a few hours here and a few hours there. It's based on Norm Abrams' plans, which really need to be scrubbed. I bought the hardware kit from Rockler. They didn't include clamping bolts and leveling screws with the kit, which I didn't discover until I was about ready to mount the router. I dropped the first table top and had to build another one. One of the screws broke off in the router when I attached the base, so I need to tap it. I'm just glad to be done with it. I do like the storage space that this plan allows for. All but one of the little drawers are for bit storage and they consist of a drawer front and a bottom with holes drilled in it to stuff the bits. As such, the bit drawers can't store anything else. I wish I would have made one or two of them conventional drawers for a little bit more storage for small items. The one conventional little drawer filled up quick with wrenches, collets, bushings, etc.
WirelessG is offline   Reply With Quote
The Following 2 Users Say Thank You to WirelessG For This Useful Post:
BigGuy01 (12-25-2011), woodworkbykirk (12-21-2011)
Old 04-12-2011, 06:20 PM   #2
DIY staff
Rewards Points: 7,174
Looks very nice----could you post a picture of the top?
Old 04-12-2011, 09:08 PM   #3
Rewards Points: 52
Nice job! I see some scrap laying off to the side that looks like it matches the drawer fronts, so just throw it on the to do list to build a drawer to replace one of the bit storage ones. I can't get the picture larger for some reason, but are those locking casters?
Old 04-12-2011, 09:08 PM   #4
Old School
Willie T's Avatar
What do you mean when you say Norm's plans need to be scrubbed? They don't work?
Willie T
Old 04-13-2011, 09:33 AM   #5
WirelessG's Avatar
Rewards Points: 698
Thanks all. I'll take some more pics and post them tonight. Two of the casters are locking. The scrap that you see is AC ply. The drawer fronts are select pine and I used all of it. Maybe one day I'll buy some more and convert one of the drawers.
Yes, Norm's plans are kinda incorrect/confusing. He has couple blunders. I don't remember exactly what they were, but it would be something like referring to a piece of MDF, when he really meant birch ply. He lays out all of the cutting for the birch ply, but then he only describes the cutting for the AC ply and the MDF and it's easy to misunderstand his instructions as sometimes he tells you to cut a piece of certain dimensions and in the next sentence he tells you cut another piece from which yet other pieces are cut. What he tries to do is give you a rough cut for handling purposes (say cutting 3'-6 x 4'-8 out of a 4' x 8' sheet from which you can cut 3 or 4 other smaller pieces). I think Norm could have made it a lot easier if he would have used piece marks. In other cases he shows a piece of 3/4" material, but he doesn't tell you if it's MDF or ply and you just end up going through mental iterations trying to figure out what he is doing. Finally, the plan is not a guide - it's more like a series of drawings.
Norm only laminated the top of the table (I posted about this in a previous thread) and left much of the MDF fence bare. I laminated both sides and painted any bare MDF surfaces.
The Following User Says Thank You to WirelessG For This Useful Post:
Willie T (04-14-2011)
Old 04-13-2011, 07:23 PM   #6
WirelessG's Avatar
Rewards Points: 698
Here is the picture of the top that you asked for, Mike.
Old 12-21-2011, 12:25 PM   #7
Wireless-did the left two bottom doors have the right measurements on nyw plan? Thanks
nicart56 is offline   Reply With Quote
Old 12-21-2011, 01:13 PM   #8
WirelessG's Avatar
Rewards Points: 698
Yes, as far as I know they did.
Old 12-21-2011, 02:34 PM   #9
DIY staff
That is a slick looking table---Thanks for the top picture--------It helps to see the mechanics of the fence.---Mike----
Old 12-24-2011, 10:53 AM   #10
Rewards Points: 150
Nice router table.
CJIII is offline   Reply With Quote
Old 12-24-2011, 12:17 PM   #11
Rewards Points: 346
Nicer than the ones in the store. Great job!
dougp23 is offline   Reply With Quote
Old 12-25-2011, 01:01 AM   #12
Too Short? Cut it Again!
You should think about copyrighting and selling your plans if they are in a physical form. I might not make you rich but you might get a little royalty check now and then.
Of course we live in an era where generations think it is alright to steal intellectual property. If they find it on the internet the assume the can own it without compensation to the creators. Hardly makes it worthwhile to write and publish anything anymore.
Old 12-25-2011, 09:08 AM   #13
Darn thing looks nicer than my custom kitchen cabinets...........and you are going to grind wood with it???????? VERY NICE!!!!
Old 12-25-2011, 10:48 AM   #14
Rewards Points: 558
Very nice router table in deed…
epson is offline   Reply With Quote
Old 12-25-2011, 11:05 AM   #15
Facilities Maintenance
When its plugged in, is there a hole in the back of it to run a cable through to power it? or do you bring the extension cord in from the front of it?
BigGuy01 is offline   Reply With Quote
Bench Dog router table whejdak Carpentry 3 04-01-2011 05:31 AM
Router Table gmhammes Tools 8 06-27-2010 11:32 AM
crappy router table wwpro Tools 20 01-19-2010 06:30 PM
Router Table adpanko Project Showcase 6 09-04-2009 02:33 PM
Shutoff switch for custom Router Table. mfleming Electrical 14 11-13-2008 01:50 PM
