Finish Work Around Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-07-2013, 09:02 AM   #1
bryanp22's Avatar
Rewards Points: 290
Finish work around window
We are finishing out basement and we have old basement windows with a 45 degree bevel of concrete from the cinderblock. I've framed up to the block but the concrete is still exposed. What's the best way to finish up to the window? Just run a board to the concrete bezel? With how the latch is setup I don't think it gives me many options to chip away the bezel to butt the board right up next to the concrete.
Finish work around window-image-1908190400.jpg   Finish work around window-image-3542080878.jpg
bryanp22 is offline   Reply With Quote
Old 09-07-2013, 10:01 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
build up the framed sil so its level with the framing in the actual window opening. that way you can hide the concrete with either drywall returns or a wood jamb extension
woodworkbykirk is online now   Reply With Quote
Old 09-07-2013, 11:07 AM   #3
bryanp22's Avatar
Rewards Points: 290
What about the latch. You can just barely see how it's cut out in the concrete in the second picture.how do I accommodate that?
Old 09-08-2013, 09:27 AM   #4
Rewards Points: 236
i would caulk and paint. looks like space is limited right there. i would not want to use up any of what little is there.
Fix'n it is offline   Reply With Quote
Old 09-09-2013, 11:10 AM   #5
Rewards Points: 454
he can do this but it doesn't look like he will have enough clearnce to open the window
scottktmrider is offline   Reply With Quote
Old 09-09-2013, 12:05 PM   #6
bryanp22's Avatar
Rewards Points: 290
I think I am going to just put a window box up to the concrete bevel and then caulk the gap between the concrete and the window box. any tips for touching up the concrete to make it smooth? I just have a small trowel is that not the right tool?
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 08:52 AM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
