Filling Holes In Stained Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-20-2008, 05:33 PM   #1
Filling holes in stained Cabinets
Just wondering if anyone has any suggestions as to what is the best stuff to use. The cabinets are stained oak. Thinking about trying minwax's stained wood putty, but I think there would be a better way.
220-221 is offline   Reply With Quote
Old 12-20-2008, 08:02 PM   #2
Lost in Space
I find the best thing to use are the "wax" crayons, you can find them in the stain department. When you order new cabinets they usually include one that matches pretty well. They are easily to apply and easy to clean up.
Tool Junkie is offline   Reply With Quote
Old 12-20-2008, 08:10 PM   #3
General Contractor
The crayons are the way to go.
We use Mohawk Blendal Sticks although its a bit much for a one time application.
jensenconstruction is offline   Reply With Quote
Old 12-20-2008, 08:13 PM   #4
If they're already stained and finished, colored wood putty or filler crayons are about all you can do. What size holes are you talking about?
With the putty, you can blend a couple different colors together if you can't find an exact match, you can even blend them so it's not a solid color, with a little swirl if the hole is bigger, like a screw hole. That helps to hide it a little better.
I'm actually not a fan of the crayons, I prefer the putty.
Jeeper1970 is offline   Reply With Quote
Old 12-27-2008, 01:15 PM   #5
I agree with Jeeper. I always used the putty. Find one that matches to your suiting, may have to mix them. Take a small amount and roll it between your fingers to make a point. Stick the point into the hole to insure good fill, then simply smudge it off. After all holes are filled, I usually take a rag with small amount of mineral spirits on it, and wipe everything down.
jasonckcmo is offline   Reply With Quote
Filling Voids on Stained Baseboard jasoncw Carpentry 10 12-16-2008 10:46 PM
Filling holes in trim........is it going to be smooth yummy mummy Building & Construction 8 12-07-2008 12:46 PM
Staining cabinets that have been stained 2 different colors? digexpressions Painting 6 07-26-2008 12:42 AM
Filling wood panel nail holes Sarah24 Painting 1 03-14-2008 12:48 PM
Filling nail holes on paint grade trim? Yeti Carpentry 3 10-07-2007 09:53 PM
