Figuring Angle - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 04:42 PM   #1
figuring angle
i am attaching a lean-to top to an outdoor building. The place we put the ledger board is at an angle. It's a barn shaped building. We don't know how to figure the angle.
Lindareagan is offline   Reply With Quote
Old 05-30-2011, 05:16 PM   #2
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Put a framing square on the rafter and use a level to make sure the either the vertical leg of the square is plumb or the horizontal leg is level. Then measure from the corner of the square vertically (the rise) and horizontally (the run) to the rafter. Try to maximize the dimensions that you are measuring by pulling the square away from the rafter - this will give you a more accurate reading. The angle measured from the horizon up to the rafter will be the arctangent of rise divided by the run. If you want to set your miter box the angle would 90 degrees minus the angle that you just calculated.
WirelessG is offline   Reply With Quote
The Following User Says Thank You to WirelessG For This Useful Post:
Willie T (05-30-2011)
Old 05-30-2011, 06:11 PM   #3
kwikfishron's Avatar
Rewards Points: 824
You can also hold the rafter stock against the side on the ledger and the beam on the other side as it's going to sit and just scribe it. You can scribe the seat cut too. You can frame your lean-to without ever even having to know what the angle is.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
oh'mike (05-30-2011), thomasjmarino (05-30-2011)
angle grinder question itin1200 Tools 8 07-13-2010 07:07 PM
Is It Okay To Hang A Sheet Of Drywall On An Angle? moondriver Drywall & Plaster 12 05-01-2009 03:22 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 09:33 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 04:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
