Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-22-2011, 05:36 PM   #1
Figureing lap siding?
I wondering how do you figure lap siding for a 12x18 shed with 8' walls and a 4/12 gable roof, with gable in walls. I wont to use 1x8x12' siding.
CJIII is offline   Reply With Quote
Old 11-22-2011, 06:19 PM   #2
Mod
kwikfishron's Avatar
Figure out the sq. ft. of the walls, width times height. For a gable figure W x H divided by 2. Add all of the numbers up for total sq. ft. then deduct any large openings.
1X8 would be a 6” exposure so take the total sq. ft. and multiply by 2 then add 10% for waste and that will be how many lf of siding you need (+/- a fuzz).
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 11-22-2011, 06:41 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
kwik is right.. the only thing with if your siding up into a gable end, youll have to account for some extra waste
woodworkbykirk is offline   Reply With Quote
Old 11-22-2011, 06:52 PM   #4
Mod
Which is why I don’t deduct for most windows unless there large like a patio slider or a wall of glass. I usually will have some returns at the end but that’s better than running short. Keep the siding “clean” and returns aren’t an issue.
-NEW MEMBERS-
Old 11-22-2011, 08:25 PM   #5
yah gable ends are always a bugger for waste.... thats the killer with the newer hardie plank which has the log stamped on teh top edge... the old stuff you could just flip over and use as a starter on the other side
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 07:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
