Figuing Sheathing For A Hip Roof? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-09-2014, 08:25 PM   #1
Rewards Points: 150
figuing sheathing for a hip roof?
Would 9 sheaths of 4x8 osb covering a 12x20 hip roof?
CJIII is offline   Reply With Quote
Old 02-09-2014, 09:03 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Area of a triangle
1/2 base x height. Break the roof up into rectangles and triangles and figure the area. Simple as that. You didn't mention the pitch of your roof and if there are any overhangs involved.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
woodworkbykirk (02-10-2014)
Old 02-09-2014, 09:28 PM   #3
Rewards Points: 150
Its a 4/12 with 12'' of overhang.
Old 02-10-2014, 07:05 AM   #4
Rewards Points: 1,294
Are you doing all 4 sides of the roof or just one? Is the 12 x 20 the footprint of the structure under it?
If the roof overhangs are added to the 12 x 20 then I get 9.625 sheets of area. You need to figure in for scrap. If the actual roof size is 12 x 20 then I would guess you should be good
danpik is offline   Reply With Quote
Old 02-10-2014, 06:14 PM   #5
Rewards Points: 150
I will be doing all 4 sides.
Old 02-11-2014, 06:07 AM   #6
Rewards Points: 13,694
A hip roof can be done several different ways, not sure how anyone could tell you how much is needed without more info.
It could be as simple as 3, triangles, or a long ridge pole in the middle with angled sides.
http://www.blocklayer.com/roof/RoofEng.aspx
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 05:23 PM
Sheathing for concrete tile roof? RM575 Roofing/Siding 3 08-04-2013 10:03 PM
Protecting patio roof from water comming from house roof alekas Roofing/Siding 2 07-30-2013 09:40 AM
Roof Sheathing Thickness Clutchcargo Building & Construction 8 09-23-2009 01:13 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
