Fieldstone On 1920s Home - Column Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 05:11 PM   #1
fieldstone on 1920s home - column problem
does anyone know how field stone was typically installed in the 1920's?
I have just purchased a home with fieldstone facade.. my guess is that instead of a cavity wall they adheared the stone directy to the sheathing.... any thoughts?
one more item... im a bit upset i didnt notice this when i inspected the house...
notice the columns on my front porch. i noticed today they are bowing outward quite a bit.. the previous owners have been adding mortar between to attempt to repair but i believe this is making the bowing worse with time.
any suggestions how to straghten out these columns? i was thinking i would chip out all the mortar in the cracks, jack the columns back so they are stright again, then remove one stone and drill into the wall beyond and mortar in a rod to tie the wall to the column. then remortar the crack and any joints that cracked when i jacked it. but im looking for more opinions..
thanks!
https://picasaweb.google.com/lh/phot...eat=directlink
shaner123 is offline   Reply With Quote
Old 03-16-2011, 05:14 PM   #2
sorry i ment to put this thread in construction.
Old 03-20-2011, 12:18 AM   #3
thanks!
I think it was directly adhered to the sheathing. As for the columns, are they load bearing?
JB818 is offline   Reply With Quote
Old 03-20-2011, 06:58 AM   #4
DIY staff
Rewards Points: 7,174
Wow,Handsome house! Can someone capture and post his picture?
I'm not a mason---(or a computer geek)--Mike---
Old 03-20-2011, 07:58 PM   #5
yes.. the columns are bearing..
im curious if there is a wood post inside them.. im sure there must be.
the weight of the roof is bowing the columns outward and without stripping off the fieldstone veneer i would like to realign the columns and prevent future failure.
Old 03-20-2011, 09:19 PM   #6
You have to make sure the wood beam is sound.
Old 03-20-2011, 09:34 PM   #7
the beam above is fairly sound.. however i am going to reinforce it by sistering it on the inside because it is sagging a couple inches in the centre... its the 2 columns im worried about!
Home Reno Wiring Problem Henry H Electrical 17 05-21-2010 08:24 PM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 11:36 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
modular home flooring problem wen Flooring 1 08-15-2005 01:11 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
