#1 |
Fiberglass Door Question
I have a wood exterior door I would like to replace with a fiberglass unit. The door measures 32x93, It's not your usual size so I thought I would just order the door itself and install on existing jambs. The question I have is, can I chisel out the hinge areas like you would do on wood doors. I have no experience working with fiberglass doors.
Thanks Rich |
#2 |
This would not be the way to go. If your're upgrading the door, do the prehung unit. The weatherstripping on a prehung unit is much more effective and neater then some applied aftermarket material.
Depending on the house exterior, you might be able to change the opening to a current standard size instead of ordering a special size at a premium price. Maybe order a door with a transom to take up the extra space on top. Ron |
#3 |
There in lies the problem, The house is stucco. I don't feel like tearing into that. Besides I can order a (door only) for around 300 dollars. The other option is Home depot for a pre hung and all for 900+. I'm wanting fiberglass because the old wooden door is prone to rain water being blown on it and the bottom rotting out.
#4 | |
Fiberglass Door QuestionQuote:
By reducing the height you would be filling in the space not tearing into the stucco. You could do it your way, the hinges would just be mortised into the fiberglass door to line up with the current frame. Ron. |
#5 |
Thanks for input Ron, so I could just use a chisel on fiberglass like on a wood door?
#6 | |
It's like a fiberglass sandwich, with the fiberglass as the bread, and the wood as the turkey. Ron |
| Display Modes | |
| Exposed fiberglass insulation in partially-finished basement | skysurf | Building & Construction | 1 | 04-11-2009 10:40 AM |
| fiberglass vs paper - revisited | rtoni | Building & Construction | 3 | 03-25-2009 07:50 PM |
| Corrugated Fiberglass Roof | theriver | Roofing/Siding | 1 | 09-16-2008 10:37 PM |
| Is fiberglass insulation safe for us with dishwasher? | jen78fl | General Discussion | 10 | 01-31-2008 06:51 PM |
| Using fiberglass filler on a balcony | darsunt | Painting | 2 | 12-31-2006 09:13 PM |
