Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-15-2008, 10:08 AM   #1
Question
a few interior door install questions
1. to provide adequate gap spacing for drywall, i was gonna set small pieces of drywall at various spots along the door frame on each side between it and the 2x4 before i start fastening it. is this the standard technique ?
2. does it matter at which parts of the door frame i shoot nails in and at which frequency (every how many inches) ?
3. this is a bathroom door and the floor inside will be tile and outside i do not know yet - either tile or carpet, not sure. so, to demarcate, i was gonna set a good ole oak plank threshold. it needs to be slightly wider than 4", so i got a piece of 1x6x6ft oak plank ($17, ouch) to cut it to fit each way. since the floor is concrete and i do not believe in glue, i was gonna drill four holes for anchors in the concrete, and in the sill, i was gonna pre-drill four shallow holes (not penetrating through) wider than the screws and then drive the screws through the bottom of them and into the anchors. to make the screws invisible, i was gonna cut small plugs out of a dowel stick fitting into the wide pilot holes, glue them and sand them before applying finish (glue is fine in this low key application ). does this sound like a viable plan ?
Old 10-15-2008, 02:48 PM   #2
Another DIY Zombie
Regarding the Drywall scabs, etc. I would advise that, but keep in mind that it is doubtful that you will be able to get both sides of the door jamb to line up with each each wall (inside and outside), so the advice is to make the more visible side the tight one. For instance, on my bathroom door, the entrance is about 40" wide. I have a 32" door. On the hallway, the wall has a good 2' before the next opening, so I kept the door snug to the hallway, and let the jamb extend into the bathroom a bit. Basically with my trim up, there is a slight gap (1/8" behind the trim) that is not seen.
Regarding the nailing, I set the door in place, level and nail the hinge side first, then nail the latch side such that the door will be properly adjusted.
Also, I usually put 2 nails in the top, bottom, and middle (near the hinges), similar to the latch side. Make sure you use blocking where you are nailing, or the door frame may rack on you.
javan is offline   Reply With Quote
Old 10-15-2008, 03:21 PM   #3
Question
what is a jamb ?
what is the latch side ? is that the side of the frame on which the door is hinged.
i'm a total door imbecile.
thanks.
Old 10-16-2008, 07:14 AM   #4
Another DIY Zombie
Jamb is also known as the frame (two sides, and top)
Latch side is the side with the recess for the door latch strike plate
Hinge side is the hinge side
Old 10-17-2008, 04:29 PM   #5
Some things are done differently depending on where you live, codes, etc. That being said, here in my world I usually don't install the doors until after the sheetrock is hung. This makes haning the rock easier and installing the door easier. Also, whenever I'm putting tile in a room, I don't hang the doors until the floor is done, because the door jamb (frame) usually sits directly on top of the tile. I usually extend the tile into the door opening so that the transition from tile to 'other' is directly under the door when it's closed.
To answer the other questions, I usually set the hinge side of the jamb first, generally with a nail on either side of the doorstop about every 12-16 inches down the leg. The other side of the jamb I usually adjust so that the reveal (gap between the door and frame is consistent all the way around, using shims (cedar) to fill between the jamb leg and the rough opening.
CLear as mud?
o_jay66 is offline   Reply With Quote
More On This Topic
How to Choose Drywall
How to Choose Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about choosing drywall. There are a lot of different choices when you choose drywall. The drywall that I have chosen for this project is 5/8’s of an inch thick... Read More »
Spanish tile has been used for centuries on roofs, and some of these old, historical roofs are still in existence. There are times when repairing a Spanish tile is necessary. Read this eHow to learn more. Read More »
When a home is remodeled, people often make changes in appliance placement. Sometimes, whole rooms change functionality. When this happens, laundry chutes can become obsolete. Leaving them visible creates the risk of accidental use—and trapped... Read More »
We finished our drywall. We put our first coat on yesterday, of drywall mud to seal up all the joints and the nail holes. This morning I came in and finished the top layer of the drywall. I used a twelve in knife which makes a nice wide band here, makes... Read More »
In this clip, we're gonna add windows and doors to our house. We've got our bag loaded with icing, and we're using our plain tip number three which is just the plain round hole. You can use any tip really if you want, as I'll show you, we'll use a... Read More »
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Hey gang, another Neewb here! 261,483 questions to follow! Portlandkids Flooring 6 08-30-2008 09:34 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 10 10-15-2007 09:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
