Fence On Staggered Property Line - Carpentry - Page 4 - DIY Chatroom Home Improvement Forum
Old 07-17-2013, 11:03 AM   #46
Bill Kearney
Rewards Points: 1,174
If the neighbor behind you is game and wants to have a similar looking run all the way across his yard then it'd be nice to coordinate it all at one time. Same thing for the neighbor next to you.
But don't rule out having a gate there. Several neighbors have them and it's really convenient for the kids. They don't get used "all the time", as that would border on getting kind of rude. It's mostly just when the stray frisbee, ball or other toy goes over.
wkearney99 is offline   Reply With Quote
Old 07-17-2013, 12:11 PM   #47
concretemasonry's Avatar
Rewards Points: 2,570
After doing some surveying, is really very rare when everything at "square" or even have a couple of exact 90 degree corners. - This is especially true in areas where the is some sort of magnetism where the original surveying was often done ears ago using magnetic directions or even the old "meets and bounds" system that had to modernized when the old trees, streams and rock had disappeared.
Before doing anything remotely related to property lines, make sure you know where the pins are and they have not been disturbed since being set. - It gets very costly, complicated and inconvenient to correct or adjust. After that decide if you want the fence to be on the property line and co-owned or on one side or the other where the ownership, appearance and maintenance is well defined.
Dick
concretemasonry is online now   Reply With Quote
Old 07-20-2013, 09:28 PM   #48
Rewards Points: 81
I really cant see how building on the property line can be a good thing in the long run. What happens when you or one of your neighbors decides that the fence you chose looks cheap and decides to upgrade to a better product. Now that corner post becomes an issue of contention between neighbors. If it was on my property, I would not consent to having a fence installed on the property line, if only to prevent future problems.
one cut is offline   Reply With Quote
1860 victorian lead line issues / neighboring property dispute Lesnocker Plumbing 10 09-07-2012 07:42 PM
6' wood privacy fence questions snosurfa7 Landscaping & Lawn Care 13 06-01-2012 02:45 AM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
