Fence Boards Flush With Post - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-21-2009, 10:50 PM   #1
Rewards Points: 518
Fence boards flush with post
I need to build a small section of fence and I want to know what the best way is to get the fence boards flush with the posts are like in this picture:
n0c7 is offline   Reply With Quote
Old 08-22-2009, 02:05 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Like on the L.H. side?
It looks as if they used finishing nails to fasten the field boards to 2 horizontal nailers on the back side.
This is an unusual way to build a fence. Most similar fences have a "reveal" an offset between the post and the field. There is no issue with using galvanized finishing nails.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-22-2009, 09:32 AM   #3
Rewards Points: 518
Yep just like on the left side. I think it looks pretty good having the boards flush with the posts but can't quite wrap my head around the best way to accomplish this.
Old 08-22-2009, 10:19 AM   #4
Does the other side look the same?
Mark a line on the posts the depth of the fence boards
Secure a 2x4/nailer board just behind that line between the posts
Now when nailing the fence boards they will be even with the posts
If you want the top board also even with the posts then you need to go back the thickness of that board
Old 08-23-2009, 04:17 PM   #5
Rewards Points: 518
Thanks guys, figured it out.
Setting A Fence Post gotboost General DIY Discussions 9 01-23-2011 08:40 AM
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 02:20 PM
fence post frasc Building & Construction 2 08-13-2009 01:56 PM
How To: Post Nathan Getting Started With DIY Chatroom 0 07-04-2008 03:08 PM
