Faux Gable Braces. - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 02:28 PM   #1
bigbearz's Avatar
Faux Gable braces.
Hey Guys,
Anyone build faux gable braces for there house? I was looking at doing something like this.. and out of cedar. My question is how to hang them? and any design ideas?
thanks
bigbearz is offline   Reply With Quote
Old 04-13-2011, 03:41 PM   #2
Rewards Points: 5,336
You'd bolt them to the house.
Ron
Old 04-13-2011, 04:23 PM   #3
KemoSabe
loneframer's Avatar
The first example is 6x6 PT wrapped in Azek PVC trimboards.
The second and third are cut from a solid sheet of Azek and attached to the PVC rake boards with brads and PVC cement.
Faux Gable braces.-046-4.jpg   Faux Gable braces.-030.jpg   Faux Gable braces.-031.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 04-13-2011, 04:55 PM   #4
bigbearz's Avatar
Ron
Just wondering about how to bolt or screw them.. how to hide everything so you can't see them. I would guess on the soffit edge where the 2 x 6 is but just wondering how to hide it all so it looks clean.
Old 04-13-2011, 04:56 PM   #5
bigbearz's Avatar
those are nice.. I like the first one and was going to do something similar out of 4 x 4 cedar... Should I seal it so it stays red?
Old 04-13-2011, 07:12 PM   #6
KemoSabe
loneframer's Avatar
I would definitely seal it before assembly but after the cuts are made.
Moisture will wick into the end grain and stain/discolor the end cuts, as well as invite decay. Today's cedar is not nearly as rot resistant as that of old growth.
Old 04-13-2011, 07:47 PM   #7
bigbearz's Avatar
thanks again Loneframer.. can cedar be clear coated or something to keep its color?
Old 04-13-2011, 08:03 PM   #8
KemoSabe
loneframer's Avatar
I would use a preservative with a UV inhibitor. It's going to have to be maintained regularly, but cedar is beautiful before it oxidizes.
The Following User Says Thank You to loneframer For This Useful Post:
bigbearz (04-13-2011)
Do I need the gable vents bjakeski Roofing/Siding 4 08-17-2010 05:17 PM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 12:55 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 07:32 AM
Changing gable over hip roof to gable end billybarty Building & Construction 2 03-11-2008 11:20 AM
Extending gable over flat roof? PricelessDharma Roofing/Siding 6 01-22-2008 12:48 PM
