Fasteners To Use With Cedar Shakes Over 1" Ext Insulation - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 08:59 AM   #1
Fasteners to use with Cedar Shakes over 1" Ext Insulation
My wall composition will be: 2x6 studs, 1/2" plywood, 1" IKO Enerfoil (R7), perhaps a breathing mesh? and Cedar Shakes/Shingles. I'm wondering what you folks recommend for a fastener (length/type)? I was thinking 2" staples with a 7/16" crown...
Thanks!
kewlgolf is offline   Reply With Quote
Old 03-05-2013, 09:16 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
Back before nail guns we used hardboard siding nails and if I was installing with the situation you have I still would. With a nail gun you have to be careful to get the pressure just right or set the plunger just right or the staple will go through the shake, same with trim nails. I do agree if you can get the gun set right a staple would hold better but if the shakes are going over the insulation the gun would be iffy IMHO.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 03-05-2013, 09:24 AM   #3
Cedar Shakes/Shingles require stainless steel or hot dipped galvanized steel fasteners!
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
joecaption (03-05-2013)
Old 03-05-2013, 10:44 AM   #4
Rewards Points: 13,300
If not your going to have black marks running down the wall.
This is what I use for shakes, James Hardee, wooden fencing ECT.
The nails have small heads and are ring shanked and near imposible to pull out once driven in.
Old 03-05-2013, 03:53 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
you cant install shingles or shakes directly over foam. you have to sheath over the foam with plywood or osb before the shingles go on if you want them to stay on the wall..
diddo about the stainless steel. all we use for cedar is ss ring nails in siding nailers, along with pine clapboard, canexel siding and fibre cement
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
framer52 (03-08-2013)
Old 03-05-2013, 04:10 PM   #6
Registered User
Rewards Points: 5,216
Photo 4; http://www.buildingscience.com/docum...d%20in%20walls
Spacer mat; http://www.jlconline.com/coastal-con...-shingles.aspx
Where do you live that you require the PIC (foil-faced)? It is a vapor barrier, do you already a vapor barrier/retarder next to drywall?
Gary
Old 03-05-2013, 04:21 PM   #7
Rewards Points: 150
Ss siding coil nails are great only issue I have is the coil is not stainless so I've seen them still leave streaks down but still best way available
kaschmid3 is offline   Reply With Quote
Old 03-05-2013, 04:32 PM   #8
Use SIP panels instead and get rid of all the issues.
Old 03-05-2013, 07:15 PM   #9
very little of the coil strip is left on the nail when its shot anyway.. so its not enough to really matter. im located on the coast where salt water effects fasteners severely .. using galvys is just a recipe for disaster though
Old 03-05-2013, 08:16 PM   #10
Roofmaster
Rewards Points: 2,172
Way back when I did this with my dad we used galvanized nails with domed heads which countersunk into the shakes.
You did not say where you are from, but I would not put foil on the cold side of the insulation if you are in a cold area. You could be creating a monster re dew point. You want one vapor barrier/retarder on the warm side stick in a few more and you are asking for trouble.
Old 03-05-2013, 10:04 PM   #11
the domed head nails you used were for clapboard siding and are meant for face nailing.. cedar shingles should be nailed with ring nails or box nails which dont protrude from the face of hte shingle
Old 03-06-2013, 02:19 PM   #12
Thanks for all the replies folks. I am from Prince Edward Island, Canada. We have a maritime climate which can get cold in the winter but fluctuates all the time.
I have decided that I will not even bother going with the 1" foam on the exterior since (from what I've read) it won't be enough to protect the plywood against moisture/condensation because of my 2x6 insulated wall on the inside.
I will go with this composition: (from inside out) Paint, drywall, vapor barrier, batt insulation, 1/2" plywood, Tyvek housewrap, some sort of breather/spacer/rain screen, and my cedar shingles. I will not have the extra R6 from the polyiso but since it's not enough anyways, and we can't really afford the extra R15 (which is necessary to keep plywood warm in my climate), we will go without. Saving $3 or $4k on rigid foam will go a long way toward the heating costs anyway.
Are there any other solutions to eliminate heat loss from thermal bridging? I know about stagger stud, and those methods but am not necessarily interested in going that route.
Old 03-06-2013, 04:32 PM   #13
for rain screen for the shingles you will need to use homeslicker or lattice. just make sure the shingles dont come in direct contact with the tyvek as the oil in cedar will react adversely with the tyvek rendering it useless for keeping water out
Old 03-06-2013, 08:16 PM   #14
Registered User
"Are there any other solutions to eliminate heat loss from thermal bridging? I know about stagger stud, and those methods but am not necessarily interested in going that route."--------------------- add some 1-1/2" wide strips ripped from 1/2" XPS to cover the studs/plates. Or thicker as wood is r-1.25 per inch... use Roxul rather than R-19 (low density) fiberglass inherent with convective loops; http://www.buildingscience.com/docum...ce-insulation/
Air-seal the plywood/framing joints against infiltration/exfiltration (IMO even with air barrier;laps taped, Tyvek); pp. 21;http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf
If accessible, foam the rims.
Gary
Old 03-07-2013, 08:11 AM   #15
Good tips Gary, thanks
Tags
cedar , exterior wall , shakes , shingles
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Paint or Stain 1983 cedar shakes in great shape? Skelleyman Painting 7 12-06-2012 10:43 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
