Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-11-2011, 01:24 PM   #1
Question
fasteners for 7/16 OSB sheathing on a shed
i sound like a total beginner but was wondering what kind of fasteners to use to hang 7/16 board as sheathing on the 2x4 studs of my shed. 3" framing nails seem much yet trim nails do not seem sturdy enough (i do have a trim nailer). should i go with screws perhaps?
thanks
amakarevic is online now   Reply With Quote
Old 01-11-2011, 01:26 PM   #2
Experienced
Jackofall1's Avatar
3 or 4d would be good,
The Following User Says Thank You to Jackofall1 For This Useful Post:
amakarevic (01-11-2011)
Old 01-11-2011, 01:28 PM   #3
Question
what is "3 or 4d" ?
Old 01-11-2011, 01:30 PM   #4
Experienced
Jackofall1's Avatar
Here check this out.....you can keep it for reference
http://www.mcvicker.com/offtech/smnail.htm
Old 01-11-2011, 01:39 PM   #5
i hope my trim nailer is 4d, going to check ... i am too lazy to be nailing manually
Old 01-11-2011, 01:42 PM   #6
Experienced
Jackofall1's Avatar
Nope, trim nailer won't handle the diameter of the nails head.
If you have a framing nailer go ahead and use that, with the minimum size nail that it will take.
Old 01-11-2011, 01:49 PM   #7
Off topic, but I see that you've posted quite a few questions related to this project, so, although it's a relatively small shed, and may not make much difference, it's oftern easier to nail your sheathing on with the walls laying down, than it is to try to hold it in place and nail at the same time. Just make sure that you square the wall up first. Also, it's not a bad idea to wear goggles, particilarly with OSB, as you'll go along with no incident for a while, and then hit a hard spot, and throw a nail back if you're not paying attention.
The Following User Says Thank You to DexterII For This Useful Post:
Old 01-11-2011, 01:51 PM   #8
Question
2" is the smallest it will take, you think that's too long?
Old 01-11-2011, 01:52 PM   #9
Experienced
Jackofall1's Avatar
Nope, they will work, and yes much easier that swinging a hammer.
Old 01-11-2011, 03:10 PM   #10
Moderator
The smallest you can use for the OSB (structural sheathing) is the 2" as mentioned, Item #30 here; http://publicecodes.citation.com/ico...002_par005.htm
Be sure to gap between sheets as stamped on each sheet face.
Gary
Clothes taking longer to dry?
Old 01-11-2011, 08:01 PM   #11
Nails should go twice as deep into the structure as the osb is deep. This means if you're using 1/2 sheathing then it would need to penetrate 1" into the stud. A 1 1/2" nail is a 6d. I would go with 8d myself which is 2". If you're hand nailing, then use a 8d sinker
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Old 01-11-2011, 08:28 PM   #12
Question
gap between sheets? why ?
also, is it better to hang OSB horizontally (8 side down) or vertically (4 side down)?
thanks
Old 01-11-2011, 10:36 PM   #13
Moderator
The gap leaves room for expansion in the humidity. http://osbguide.tecotested.com/pdfs/en/el812.pdf OSB holds the moisture or water way longer than plywood, not recommended for SPF.http://www.buildingscience.com/docum...d%20in%20walls
If using it as corner bracing and it will be inspected, blocking at all edges is required. Check with your local B.D.
Gary
Old 01-13-2011, 03:53 PM   #14
Question
so how much spacing gap should i leave between panels?
also, it is pretty darn difficult to find 2"x.113 nails in the 21 deg collation, which is what my nailer is. but they have 2-3/8. do you think that will be too long for nailing 7/16 to 2x4 studs?
also if smooth shank is OK or should it be ring shank for this application?
thanks
Old 01-13-2011, 04:45 PM   #15
Please check your facts before posting.
Ron
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
unsafe wiring to shed? lawsklsux Electrical 7 11-14-2010 01:16 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
