Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-12-2012, 12:25 PM   #1
Family room wood panel ceiling nectar stuff on the knots?
As title, just noticed that we have this nectar stuff on the wood panel ceiling in our family room.. is this normal? Any health concern, and how can we remove it and prevent it to grow back? Thanks!
ohman is offline   Reply With Quote
Old 11-12-2012, 12:45 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
It is not nectar, it is Pine sap/amber. Just sand it off and restain again. No health problems from it.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
The Following User Says Thank You to gregzoll For This Useful Post:
ohman (11-13-2012)
Old 11-12-2012, 01:41 PM   #3
sdsester's Avatar
After you have sanded and stained it again, sealing it with shellac before whatever you use as a clear coat might help keep more sap from oozing. The shellac can darken and yellow the finish slightly though.
sdsester is offline   Reply With Quote
Old 11-13-2012, 02:23 AM   #4
Question
Is it caused by moisture? It is the basement of the house so just wondering whether moisture has anything to do with this... thanks!
Old 11-13-2012, 08:28 AM   #5
gregzoll's Avatar
No, natural process of the wood. Happens more around knots. Nothing to worry about, just follow what sdsester stated and move on to the next task at hand.
Old 11-13-2012, 11:25 AM   #6
AHH, SPANS!!!
when framing houses with spf lumber that sticky sap stuff is as sticky as nails, sometimes no nails are needed! joke, but it does stick to everything and oozes out over time.
hand drive is offline   Reply With Quote
Old 11-13-2012, 06:26 PM   #7
So if I just wipe it off, would it come back again in the near future? Usually how long does it take for the sap to ooze again? This is the first time that I have seen this in the basement for the last 10 years....
Old 11-13-2012, 06:38 PM   #8
gregzoll's Avatar
It may or may not. You have to scrape it off, it will not just wipe off.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
Color ideas for wood panelled room dorkdog Interior Decorating 4 01-12-2012 12:34 AM
Installing floor in family room with high ceiling. jrwilkinsonjr Building & Construction 1 05-08-2011 03:00 PM
Exposed Wood Beam Ceiling repair - help needed abiseid Carpentry 6 01-04-2008 10:01 PM
