False Treads - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 11:16 AM   #1
False Treads
How do I properly build out the nose of a stair tread to install a carpet runner between false tread caps without having the edges of the tread cap stick out?
evereecke is offline   Reply With Quote
Old 04-20-2013, 12:37 PM   #2
MJ Force's Avatar
Rewards Points: 150
When you say carpet runner, do you mean the width of the carpet will inlay into finished wooden stair threads. ?? Or will the stairs be completely carpeted. Picture? I'm not exactly picking up what your puttin down.
There is an OSB product which is used for stair threads. It's about 11" - 12" deep and 1" thick, has a rounded nosing and can can be cut to various lengths.
A small nosing could be attached using glue and screws, however this depends on the construction and materials used in the existing stairs. Best to have a solid thread which creates a nosing IMO.
MJ Force is offline   Reply With Quote
Should I replace wall skirt when installing new retro treads on existing stairs hkeiner Carpentry 12 02-15-2013 07:21 PM
replaced stair treads dhungy Flooring 5 06-20-2012 10:21 AM
extend 11.5" Oak treads to 13"? bakerzdosen Flooring 0 08-01-2011 04:51 PM
Replace old treads with Oak treads ruler10 Carpentry 19 07-21-2010 09:55 AM
