Fair Price For Pocket Door Install? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 07:15 PM   #1
Fair price for pocket door install?
I was just quoted 2 grand for installation of a pocket door. That's demolition, reframing and installing the door. Contractor says existing 24 x 80 bathroom door can be used.
There isn't anything unusual about this install. The wall isn't load bearing and there are no plumbing pipes inside the wall.
Is this price fair? I may end up trying to do it myself if I can't get the price down.
scott490 is offline   Reply With Quote
Old 03-15-2013, 07:36 PM   #2
Framing Contractor
Rewards Points: 78
A few questions:
Where are you located?
Does this include: Permits, demo, framing, drywall, painting, finish carpentry, and all materials?
sixeightten is offline   Reply With Quote
Old 03-15-2013, 07:47 PM   #3
joed's Avatar
Rewards Points: 11,534
Get more quotes and you will know.
Old 03-15-2013, 08:17 PM   #4
Haverhill Trade 1965
A small job still has proportionately more setup. Drywall patching will take multiple trips. Where the job is relative to access to work area and material moving. Get as local a contractor as you can find to reduce overhead.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
woodworkbykirk (03-15-2013)
Old 03-15-2013, 08:21 PM   #5
Rewards Points: 12,802
Get some more prices and you will know if it's to high.
Old 03-15-2013, 08:33 PM   #6
Originally Posted by sixeightten View Post
A few questions:
I'm in NYC and yes.
Old 03-15-2013, 09:00 PM   #7
Roofmaster
Rewards Points: 2,172
No, especially in NYC it costs 30 dollars for a hamburger there. Do you realize that whith a pocket door you really need a double framed wall? The door hangs on rails between the two walls, usually built with 2 x 3's and the jambs etc will be custom. Good rails for a pocket door cost over 200 bucks then theres all the other stuff. I would go wider than 2ft though if you can.
Price check? Snow Guard installation dukedan Roofing/Siding 3 12-08-2012 09:36 PM
Looking for Fair Price to Charge on Tile KeithM Flooring 10 03-12-2008 11:03 PM
