Failing Miserably At Screwing In 2 Inch Deck Screws - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 07:49 AM   #16
the Musigician
DangerMouse's Avatar
300,000 comedians out of a job and HE'S trying to be a comedian.......roflmao
DM
Old 10-28-2008, 08:58 AM   #17
Rewards Points: 1,492
It should not be that tough to screw in. If it comes to needing that much strength, then you should unscrew the screw, drill a bigger pilot hole as deep as the screw is long, and try again. When drilling the pilot hole, you will find out if the remains of another screw is still in the hole in which case you may need to relocate the hinge.
Old 10-28-2008, 11:00 AM   #18
Enormous Member
skipjack's Avatar
Rewards Points: 87
Finally! A thread I can comment on!
I'm with Alan. It sounds to me like your screws are hitting the bottom of the previous screw hole and are refusing to dig into the solid wood. Get a drill bit that's at least 2" and drill those holes a little deeper.
My next question... and don't be insulted... it is a screw thread, after all : You do have 2" of material to screw into, right? I mean, it's not a 1/2" stud w/concrete behind it, is it?
skipjack is offline   Reply With Quote
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 04:49 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
