Face Lift On 6x6 Posts With Cedar & Rock - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-03-2008, 06:49 PM   #1
Get er done
face lift on 6x6 posts with cedar & rock
I have five 6x6 posts that I would like to dress up some how. I think I like the look when it has a slight taper from the top going down about 4', then install natural stone the rest of the way down.
I could use some tips, tricks and ideas on how to accomplish what I want.
Thank you in advance.
KB
kbrena is offline   Reply With Quote
Old 07-04-2008, 01:18 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
You could frame around the bases with some 2x4 ACQ's and then cover it with some hardy board or wonder board. and then install some cultured stone to it then cap the top with some capping stone at your desired height. take some azek trim and install it over your 6x6's with your desired taper resting on your capping stone.
or you could use some 4"x 8" x 16" block around the 6x6's and install the cultured stone over that.
just something that comes to mined.
BOB
Old 07-04-2008, 01:53 PM   #3
Get er done
Hello Bob, thanks for all your advice. You have been helping me with my uneven ceiling jousts that the five 6x6 posts I'm asking about are holding up. I took your advice and had the 2x4s delivered to build the "strong back" that you described. Thanks, I hope it works. Back to the posts... What is ACQ? As far as the hardy board, good idea. Is the capping stone just a mortar colored brick or does it look like cultured stone.
Thanks again
Kelly
Old 07-04-2008, 11:42 PM   #4
buletbob's Avatar
ACQ is a pressure treated lumber that is pressed with a chemical call Alkaline Copper and Quaternary Ammonium Compounds it is use for exterior use.
And yes they do make a cultured stone for capping. hope this helps. BOB
Pressure Treated vs. Cedar Posts for Porch missyz17 Building & Construction 15 08-22-2011 01:34 PM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 10:57 PM
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 10:27 PM
cedar posts ptbauc Building & Construction 1 08-10-2006 04:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
