Exterrior Faux Stone To Foundation - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 07:26 PM   #1
Exterrior faux stone to foundation
need advice 2 part question on how to install faux stone to exterrior foundation wall
that has 2" polystyrene insulation upto 1st level
can i just wire mesh over insulation and then skim coat and install stone
or do i need to install some type of cement boad over insulation, then start the hole process of mesh, skim coat then stone
2nd-- manufactures recommmendations say type s mortar on this forum i read alot about type m whats the diff.
FLICKERTAIL is offline   Reply With Quote
Old 04-16-2012, 09:38 PM   #2
Haverhill Trade 1965
How heavy are the stones? I would say the mesh should be fastened through foam into concrete with something like Con sert concrete screws, as the foam has no strength. If the stones are real stone, and not lightweight, I would recommend fastening an angle iron, at ground level, with expansion bolts, to start from to carry more of the weight, I would also try a masonry supply for more info.
Duckweather is offline   Reply With Quote
Tie Existing Stone Foundation to New Concrete shazapple Concrete, Stone & Masonry 5 02-18-2014 06:47 AM
Stone Basement Waterproofing / Foundation Footings? troyce1 Concrete, Stone & Masonry 1 02-26-2012 11:11 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
