Exterior Trim PVC - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 10:24 AM   #1
Question
Exterior trim PVC
I am attempting to replace the rotted wood trim on door and windows on the south side of my cedar house (NJ). I bought 4 inch PVC and rented a table saw. I believe I will have butts/no miters because I need to use 2" trim on certain verticals. Do I need to add flashing or other elements before I simply glue and nail the pieces?
scullyflynn is offline   Reply With Quote
Old 04-10-2012, 10:31 AM   #2
Rewards Points: 13,446
No pictures so it's hard to say.
If your cutting the boards to length you really needed a mitre saw not a table saw.
I use stainless steel trim head screws not nails when installing vinyl trim.
Unless your doing angled butt joints there's no glue needed.
Old 04-10-2012, 10:48 AM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Some water/weather proof caulk wouldn't hurt.
sublime2 is offline   Reply With Quote
Old 04-10-2012, 01:05 PM   #4
Next Time...New Build
Rewards Points: 150
Don't forget a drip cap above the doors and windows. My 1924 cedar house did not have any above the old doors/windows.
When replacing my windows, I trimmed them with Azek and bent up a cap for each to tuck up behind the siding.
RickyBobby is offline   Reply With Quote
Old 04-11-2012, 12:31 PM   #5
Arrow
pix exterior trim
Tried to attach 2 pix but they are too large. I'll try to zip again later. Wondering whether a replacement layer to repel moisture is needed before the PVC pieces go up. Oh, and I used the table saw to rip the length of 12' pvc.
Many thanks for your help.
Old 04-11-2012, 04:31 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
azec can be gun nailed no problem.. screws arent the only way.. but stainless steel is. if you use standard galvanized finish nails they WILL bleed.. and you'll have streaks on the new trim within 6 months
woodworkbykirk is offline   Reply With Quote
Tags
butt joints , pvc , trim
