Exterior Trim 1 1/2" Wide Rotted - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 09:12 AM   #1
Exterior Trim 1 1/2" wide rotted
Hi I was wondering if anyone knows of a good exterior trim? We currently have wood trim, which has rotted. It has fallen out in the back of the house. We have hardiplank and I don't see harditrim in 1 1/2" width, it would probably be too weak. I would like PVC but Lowe's didn't have a good size. Can wood trim be painted to make it rot free? If I bought the same and painted it.
Exterior Trim 1 1/2" wide rotted-untitled-34.jpg
monetzpond is offline   Reply With Quote
Old 03-14-2010, 10:26 AM   #2
Drywall contractor
Rewards Points: 1,070
Try Home Depot. The ones in this area have a pretty good selection of pvc trim. It seems like they carry some sort of "drip cap" or something similar that's about the width you need. Or you may find something with a profile you can use and rip it to the proper width on a table saw. If you have to go with wood and this is a recurring problem, paint ALL sides/ends prior to installation, caulk thoroughly, and re-caulk/paint often. The plastic is your best bet though.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Tom Struble (03-14-2010)
Old 03-14-2010, 11:59 AM   #3
kwikfishron's Avatar
Rewards Points: 610
I'de use cedar but whatever you use I'de rip about a 5 degree bevel or so on the table saw on the side thats sits againts the house so there is a slight slope so water won't stand which is probaly why that piece rotted in the first place.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 03-15-2010, 05:56 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Azek and Versatex are good products. If they don't have what you need at HD, then check out your local lumberyards. (actually I'd suggest just doing that first anyway)
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-15-2010, 06:53 PM   #5
Rewards Points: 5,336
You seem to be indicating the skirt board. You should be able to acquire a 5/4 x 8" polyboard from your local lumbeyard.
Ron
Old 03-15-2010, 08:26 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
i think he's pointing to rhe dripcap,which i think is installed right but the fiber cement is in the wrong place,it's sitting on top of the ''hump'' thats milled into the dripcap,that hump should be behind the panel
i may be wrong tho its hard to tell from the pic
Tom Struble is offline   Reply With Quote
Old 03-16-2010, 01:50 PM   #7
Household Handyman
Rewards Points: 1,408
Good calls, "kwickfishron" and "tomstruble". I'd like to see the photo closer (or get better glasses) but it does appear to be a bad install. Regardless of material used, the 5-10 cut is essential. It does not appear that the first run of Hardie-board had a backer either. Removal of the first run of Hardie-board and placing a metal flashing would help a lot, this can be done cosmetically over a new skirt board. And NO--wood cannot be painted to be "rot free" - -PERIOD! David
Tags
exterior , hardiplank , trim
OMG rotted wallz!! workingonit Building & Construction 25 12-09-2009 01:16 PM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 08:03 PM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 01:31 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 06:14 AM
