Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-14-2009, 01:43 PM   #1
Question exterior steel door leak?
Hi,
I have and exterior steel door with magnetic seals along the sides and top. On the bottom the sill is capped with aluminum with a plastic channel threshold. I have replaced the door sweep seal on the bottom of the door and checked to ensure that the holes in the plactic channel are clear.
Whenever we get rain with wind on the face of the door water can be seen entering my house at the lower corners of the door. Things are worse when we have snow folowed by rain. Are there better seals I can get? Is there anything I can do except install a storm door? A Storm door would make it hard to get out when we do have snow.
Thanks!
deepstuff is offline   Reply With Quote
Old 10-14-2009, 11:53 PM   #2
It is my experience that water might be migrating under the sill. Do you have a deck outside this door?
dealer69 is offline   Reply With Quote
Old 10-15-2009, 12:55 AM   #3
The threshold needs to be shaped and positioned so water runs off it and away and does not have a tendency to seep undeneath the door or underneath the entire threshold.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
More On This Topic
One area where homes are less energy efficient is around doors. Many older doors leak around their edges, and many others are simply not insulated enough to provide good energy efficiency. Making doors energy efficient is one of the most obvious ways to... Read More »
Hi. This is David Jackel on behalf of Expert Village. And I'm here to talk to you about planning for bad weather when you're booking a show at a club. Now I live in Boston and the weather in Boston is unpredictable and often terrible. So planning for the... Read More »
Knowing how to read a weather map allows a person to know what kind of weather can be expected in different parts of the world during certain times. They aren't complicated to understand, but first you must learn what the symbols mean. Read More »
Rodents such as mice and rats, are most likely to enter a building as the weather turns colder and frost starts. Their outdoor habitats may not protect them from the weather and their food source runs low as well. They are attracted to the heat within a... Read More »
Whether you are buying an exterior door for a new construction or you want to replace an older door, it is important to remember that the exterior doors of your home are the first impressions that are made upon your guest. Buying an exterior door is... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
