Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-03-2011, 12:56 PM   #1
zev
Exterior sliding doors
I want to connect a slide to the deck so that the kids can slide off the deck into the backyard.
I need to make an opening (of about 3 feet by 3 feet) in the walls of the (5 foot high) deck so that the kids can get on to the slide, but I need to make it secure for the baby crawling around on the deck. I figured sliding doors would work best to close off the opening. Regular doors would take up a lot of the space on the deck as they open and close and could be a hazard if they swing in to someone.
Any ideas how I can make easy but durable exterior sliding doors?
zev is offline   Reply With Quote
Old 07-03-2011, 01:44 PM   #2
Custom Home Builder
If you post a pic or two that would help
thomasjmarino is offline   Reply With Quote
Old 07-03-2011, 04:04 PM   #3
Architectural Designer
AGWhitehouse's Avatar
plywood...prime and paint. Put z clips at top edge to keep from falling over.
AGWhitehouse is offline   Reply With Quote
Old 07-04-2011, 09:15 AM   #4
I'd use aluminum "U" channel top and bottom and make 2 smaller doors out of a composite material that opened to each side.
To keep the doors secured, you can use a hasp and a lock or drill a hole through each top and drop bolts in to keep the rugrats from opening the doors.
Ron
B. Franklin 1759
Tags
deck, porch, slide opening, sliding doors
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
