Exterior French Doors Install? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-15-2009, 06:36 PM   #1
Rewards Points: 210
Exterior french doors install?
I'm wanting to install 2 french doors, one from our master BR and another off from out kitchen nook.
Do french doors require expert installation? Because I'd like to try and tackle it myself even though I'm not much of a carpenter but can figure out about anything.
Both of the rooms I want to install them at already have a sliding glass doors installed. One of the sliding glass doors are normal/standard size, the other [kitchen nook] is about 72"W X 95" H. I've seen where people would install a standard size french door in that large of an opening and then add a rectangular window up above the doors to give it a larger appearance and probably to save money on having to buy a larger/custom size french door. Are these size doors expensive?
Anyways, any help or links to videos of installs are welcomed.
imola ghost is offline   Reply With Quote
Old 11-15-2009, 07:14 PM   #2
DIY staff
Rewards Points: 7,174
Welcome, French doors or sliding doors require precise leveling and a great deal of common sense.
If you do your research,read the directions carefully and use commonsense-you should be able to install one.
The door opening that is to big should be re sized to fit the door . These are going to be hard enough to install for a beginner,with out adding a window build job on top of it.
--MIKE--
Expensive is a relative thing.Expect $1000. or so.
Anderson is my favorite,Pella I charge $150 Extra and offer no guarantee.
To many call backs and unhappy customers.
oh'mike is online now   Reply With Quote
Old 11-15-2009, 09:09 PM   #3
Registered User
Rewards Points: 4,912
http://books.google.com/books?id=pnq...0doors&f=false
From: http://books.google.com/books?ei=8h0...doors&as_brr=3
Be safe, Gary
Old 11-16-2009, 06:06 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Thanks Gary, I just ordered your recommended Door book
I bought it online used. The new price was unreasonable.
http://www.amazon.com/gp/offer-listi...condition=used
I like the "Doors" book cover pic showing that cool door bench and also that cool old drill with a Jacobs chuck. I have an old Craftsman all metal drill similar to the one on the cover. The O.P. should also note the Templaco full length hinge template leaning against the wall. I recommend the O.P. use one of these. They also are available for other hinge sizes & styles.
http://www.templaco.com/html/template_base.asp?id=178
The second book I would recommend is the Gary Katz "...Hanging Doors" book:
http://www.amazon.com/Installing-Han...8366039&sr=1-1
I got my copy when it first came out in 2002 at Gary's all day seminar on "Hanging Doors"
I would recommend to the O.P. that he first get both of these books then after reading them if he is still hopefully enthusiastic then buy a cheapo hollow core door from HD or LOWE'S (~20-30$) to practice on before spending the big bucks.
Let us know how things work out.
Exterior french doors install?-door-book-fh.jpg   Exterior french doors install?-door-book-katz.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Masonite pre hung doors sticking hot weather Pawl Carpentry 4 07-08-2008 05:26 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Shed doors Jshakour Carpentry 5 07-06-2008 09:50 PM
How to measure for new pre-hung interior doors jencampo Carpentry 3 03-25-2008 01:49 AM
Closet Doors for non standard closet dimensions jherschel Carpentry 7 02-22-2008 05:45 PM
